soulman123
December 31, 2012, 4:00 pm
Whilst enjoying (not really) a drive in the rain as I parked I accidentally flicked the quick wipe which juddered and stooped 1/4 way on the screen if I use it again does the same till eventually its back in the home/park position. If I'm sad enough I can start it all again.
Interestingly it works fine when used normally no juddering or stopping randomly at all which chucks my theory of a wiper linkage fault ?
Do you think my wipers have had enough of being used on quick wipe or a non focus physcological fault ?
..forgot to add on wash wipe its fine aswell.
December 31, 2012, 5:36 pm
I'd get the intermittent relay checked.
soulman123
January 1, 2013, 9:24 am
How do stoney
I'll dig the haynes manual out, guessing this lives behind the glove box.
I guess time to google how.to test a relay hehe.
January 1, 2013, 11:14 am
To test a relay you apply 12v across the two low voltage pins and should hear the relay click.
If you don't then the relay is shot.
January 1, 2013, 11:19 am
if the terminals are numbered, 85 and 86 are the trigger or coil.
soulman123
January 1, 2013, 2:28 pm
Thanks stoney and stef, I will give it a go. I have a 12v supply hiding somewhere.
cuke
January 2, 2013, 9:38 am
Hi, sounds like they are going into the service position..
mjt
January 2, 2013, 10:38 am
I had this exact same fault. It was burned contacts in the relay. See [url="http://www.fordownersclub.com/forums/topic/29652-intermittent-fault-with-flick-wipe/"]this thread[/url], in particular the last entry.
soulman123
January 16, 2013, 7:37 am
mjt I will have a read of that now.
with the extreme cold I have had no luck getting out there.
The fault is intermittant, my local garage said its common and that the park motor is knackering .. his exact works. He said change the linkage eh wall another quote.
I leave it as it is and check the relay first as the wipers still works as they should. Also ill have a read of the link mjt kindly gave.
soulman123
January 16, 2013, 7:38 am
Out of interest is this classed as an MOT fault ?
soulman123
January 16, 2013, 7:52 am
[quote name='mjt' timestamp='1357144737' post='223969']
Very interesting read, looks like you've done battle with it.
I bet this is my problem as others have mentioned.
My concern us getting to this relay, is it hiding behind the glove box ?
How to you drop it down/access it ? please say a few screws and it drops in to view lol
Also where did you locate the relay for £5 sounds better than coughing up £24!
thanks again for your post its been very interesting and helpful. *thumbs up*
Andy H Dibley
January 16, 2013, 7:57 am
Had this happen to me on my 08 Focus a few times, but always works normally 99% of the time so I don't worry about it.
What triggered it off last time was leaving the wipers on full speed and driving in traffic. They do that thing of stop wiping when I stopped, I then went to creep forward, they started to wipe, I braked and so did they!
It has also happened on the quick wipe setting. To make sure it wipes keep your finger held down on the stalk for the entire wipe.
Andy H Dibley
January 16, 2013, 7:59 am
[quote name='soulman123' timestamp='1358343515' post='227343']
Highly doubtful, at most I believe the inspector checks intermittent, normal speed and fast, add to that, the ability to clean the screen in a number of wipes.
Quick Wipe Fault
