OK, it looks like Fiesta ST stuff will go straight on. The only problem is the disc diameter will increase from 258 to 278 mm which isn't a big improvement but will increase unsprung weight. So I've decided to go with standard size discs, uprated pads, braided hoses.
What do people recommend these days for uprated pads?
Cheers :)
Cheers :)
The size and weight of the disc & pads is a compromise or balance between weight and braking power
Because the unsprung mass includes the wheel, tyre hub and partly some of the axles/ suspension components, the extra mass of the slightly bigger disc etc may be realatively insignificant, the extra surface area of disc reduces fade, the extra contact patch between pad/ disc improves "bite" friction and wear rate, the larger diameter disc increases leverage on the wheel
258 to 278 does not seem a big difference, but is a bigger difference than it seems, once the diameter of the hub is subtracted (the "middle bit" :) )
Personally i would stick to Ford pads, they are good all round for initial bite, fade resistance and wear, unless you are going to go for EBC yellowstuff pads - "harder" "race" pads may be good for very heavy use but may lack initial "bite" and require more pedal pressure
A set of new (stock) discs and pads, properly bled and run-in with calipers that work ok (not sticking etc) and the brakes in good condition, should work pretty good
I dont think you mentioned what the problem was with the brakes
They just need replacing, they're old and lipped, so it presents an opportunity to upgrade.
