john34
January 11, 2013, 1:17 pm
hello
can any body help me find a wiring diagram for the glow plugs as my 60 amp slow blow fuse keeps blowing
glow plugs seem to be ok the glow plug rail is not grounding out so i am a bit stumped relay seems ok
its a strange one lol
thanks a lot
john
January 11, 2013, 11:17 pm
What model and year is the car?
john34
January 12, 2013, 8:28 am
sorry forgot
its a 2006 06 reg 2.0 tdci 115
January 12, 2013, 10:41 am
Have you measured the resistance of each plug?
January 12, 2013, 10:43 am
Here you go then.
[IMG]http://i1130.photobucket.com/albums/m522/stoney871/scan0002-1.jpg[/IMG]
john34
January 12, 2013, 2:04 pm
Hi
Thanks very much for the diagram it's very good but I have Haynes
I needed ford diagram as Haynes is a typical and not the same
But thanks for that
I have tested resistance on plugs with multimeter
Continuity test and it comes up 0.6 ohms that's each plug out the engine
I have put them back in and put rail on but took the poss wire off rail and put fuse back in
And it has not blown so it is the rail I have used a wire with 20 amp fuse and put from poss
Of battery and put it to the rail and it pops the fuse
So some where its going to ground
How can I test each plug as they all glow nice when each one is put to the battery
Thanks a lot for your help
John
Dan62
January 13, 2013, 4:30 am
[quote name='john34' timestamp='1358021096' post='226124']
If each plug is 0.6 ohm, assuming 12v supply that's 20A for each plug.
Do you know for sure that the 60A slow blow fuse is the correct rating, based on the above you should be looking at a fuse rating in excess of 80A.
January 13, 2013, 4:36 am
Im sure Haynes quotes something about each plug drawing about 15A? Ive still got my old set from the 2.2 that i could measure to confirm this for you - both engines probably use the same plug anyway.
john34
January 13, 2013, 5:02 am
Hi
Thanks for your replys it all sound true and good but my car did work and Haynes engine fuse box F8 and ford have it as a 60 amp slow blow so it is right
I have taken them all out and rail off
Tested each plug on battery with 20 amp fuse and all work no problem
But am I right in saying if they are all in and I put my 20 amp wire on the rail the fuse should not blow but the plugs won't work because they don't have enoght amps to work
I have brought a new glow plug to test it's ohms and that is 0.8
So does any one know how to test these plugs
And where are all the engine earth straps so I can check them
Thanks a lot
John
January 13, 2013, 5:37 am
0.8 ohms @12V would theoretically work out to 15A a plug - which is correct (given the 60A fuse)
with all 4 plugs connected to the rail, they will blow a 20A fuse - the fuse is simply an over current device.
it does sound like 4 new plugs will solve your problems though
Dan62
January 13, 2013, 5:38 am
[quote name='john34' timestamp='1358074931' post='226294']
Hi
Thanks a lot
John
Each of your old plugs draws around 20A so testing individually with a 20A fuse is marginal but will work.
Drawing more current through a fuse causes it to blow, a fuse does not restrict the current it supplies so connecting a 20A fuse to a circuit that draws 80A the fuse will blow.
The new plug you got (0.8 ohm) will draw 15A so it looks like you need to replace all of them to work with a 60A slow blow fuse.
I wouldn't worry about the earthing straps, any resistance in them would cause the plugs to draw less current, not more.
john34
January 14, 2013, 5:14 am
Hi all
As a update I changed my plugs and all is working again now
Thanks a lot for all your help
John
January 14, 2013, 5:15 am
[quote name='john34' timestamp='1358162074' post='226643']
Hi all
John
Good news then, thanks for the update John
