msrs
January 12, 2013, 7:41 am
hello i have just bought a focus 51 plate , it has central locking , [ intermittent fault ] works when it wants to , also there is know remote for it , i have to use the key , can i buy another remote for it ,if so where from and how much , any info / help woud be appreciated thank you
January 12, 2013, 9:40 am
Hi MSRS, when you say it works when it wants, do you mean it only unlocks one door periodically? is it related to temperature perhaps? Do you hear the other doors click in as if they try to unlock?
As for the remotes, if your car previously has had remotes then you can buy them and code them without too much agro, but depending on the variant of focus and due to the year, I *think* there were some of the lesser spec had the option of being built without remote central locking (who on earth would choose to do that
Let us know the info and we can see what we can do for you!
... Oh and welcome along
msrs
January 12, 2013, 3:35 pm
hi thanks for the reply , when i put the key in , you can hear all the locks working and does unlock all the doors , it a ford focus 1.4 cl , 2001 model if this helps thanks
martyntdci
January 12, 2013, 4:09 pm
from your previous statement abouve, whats the problem? except for the remote bit??
January 13, 2013, 2:05 am
When it falls over does it open one door onlu?have you tried unlocking from passenger side?
Dan62
January 13, 2013, 6:42 am
[quote name='msrs' timestamp='1358026546' post='226182']
Check the minor features section of your car here; http://www.etis.ford.com/vehicleSelection.do
In the expanded list it should say "[color=#000000][font=Verdana, Arial, Helvetica, Trebuchet, _sans][size=2][background=rgb(240, 248, 255)]With Door Entry Remote Control Unit" if factory installed.[/background][/size][/font][/color]
January 13, 2013, 12:24 pm
I'm pretty sure that the CL version did not come with remote central locking, i'm pretty sure it was only on the LX and above.
January 13, 2013, 7:17 pm
Cl does not have remote locking via remote only via the key
msrs
January 14, 2013, 7:13 am
thanks to members for the info about my central locking
PaulHere
January 14, 2013, 4:20 pm
I've got an 2001 1.6 LX - the central locking works fine from the key remote but can't be locked from the front internal door lock tabs, the fuses are fine (can't see if it has the mystical fuse 63) but I'm not sure what to look at next.
January 14, 2013, 11:30 pm
Hi PaulHere, so your saying the car locks properly remote and not from the outside, but if you sit inside the car and try to lock the car from the door locks, only the one door is locked?
PaulHere
January 15, 2013, 10:36 am
Hello jeebowhite, that's right.
just to reiterate:
The remote key fob works fine to lock and unlock all doors.
The central locking does not activate from the door locks inside the car, only one door is locked when you press the tab.
January 15, 2013, 10:42 am
Sounds like a potential loose connection on the solenoid on the drivers door... How comfortable are you stripping the door down?
PaulHere
January 16, 2013, 11:34 am
I'm more afraid for the door
Any tips for removing the door card?
Central Locking
