john34
January 22, 2013, 12:19 pm
hi all
i have a 06 reg 2.0 tdci lx 115 mondeo
my problem is heated front windscreen it does work lol
the light will come on but on for about 20 seconds and go off
i have taken out the relay and put a wire in there and the screen works the light on the switch comes on and it works no problem i have brought a new relay
i have no blown fuses
i have got error code from the gem b2256 front windscreen heater relay short to ground
i need a ford wire diagram for the heated screen with ground placements if any one can give them to me that would be great
any ideas where the problem may be
thanks a lot
john
ppeter7
January 22, 2013, 3:04 pm
have you removed the scuttle panel to check the wire s of both sides of screen are ok or intermittingly shorting causeing a fault
January 23, 2013, 7:30 am
good call from Peter there, thats the best place to start, and also try swapping the fuse with a like for like in the fusebox. see if the fault follows or stays...
john34
January 23, 2013, 7:55 am
Hi
Thanks for the input
I shall have a look at the scuttle panel I was going to pull a fuse to each side and see what side it might be
It's just a case of elimination
Thanks I shall try and update how I get on with it
Thanks John
john34
January 27, 2013, 7:45 am
hi
after a bit of time i have cleared the error in the gem and my screen works
but only for 6 seconds then goes off and wont come on again
i do have another fault code it says p1632 smart alternator fault sensor/circuit
dont know if this can be a problem but my battery is getting charged
thanks
john
January 28, 2013, 9:08 am
Hi Johnm
When you drive do you have a battery light appear on the dash? if so its possible the alternator is faulty.
If you get no lights, then it could be a poor charging battery, is it one you have bought, or is there a chance its the original battery? - can you confirm that the battery terminals are secured down, and where they grip around the electrodes of the battery, that you have about 0.5 - 1mm of electrode poking up from the top of the cablings...
john34
January 28, 2013, 1:39 pm
Hi
Thanks for your reply
Yes I have a light all the time testing alternator it is charging the batt
Not sure if it has the right batt on so I have took a picy
No I don't have any wire sticking out of the cable on the batt
John
john34
January 28, 2013, 1:41 pm
Here is the pic
