talksy
January 23, 2013, 4:01 am
Hi, not too sure what this could be, but I have noticed that if I am going up a slight hill, or large hill, doing around 2,000 rpm in 3rd gear, my focus is almost jerking back and fourth whilst moving up the hill. It is starting to get quite noticable and the only way to get rid of it is to put more pressure on the gas.
Any ideas as to what it could be? Doesn't seem to do it in any other gears.
Steve
January 23, 2013, 5:18 am
sounds fuel related to me.. lets see what other think
talksy
January 23, 2013, 6:43 am
[quote name='Steve' timestamp='1358939915' post='229516']
Ok, thanks for your reply. I always get my diesel from Tesco and usually fill up when the range is about 60 miles. I don't top up here and there, I normally wait unitl it is quite low and fill it with one bang.
isx600
January 30, 2013, 2:23 pm
At 1800RPM the turbo surges (more like a pause) just as the boost comes in and it starts to spool. If your having to press the peddle down and it clears the engine is getting the fuel it requires. Is the engine hot or cold when this happens and when last was it serviced, fuel filter replaced?
Try a different fuel brand. Personally I wound't run any fuel tank that low. What ever rubbish is at the bottom on the tank is just sent to the filters.
talksy
January 30, 2013, 3:50 pm
[quote name='isx600' timestamp='1359577383' post='231827']
Hi, thanks for your post.
I have had the car for about 5 months from a Ford dealership. Not sure when the filter will have been changed but I was told it had had the full service when I bought it and 'everything' had been checked/replaced if needed and to be fair, it deed seem in very good nick when I got it, brake pads etc all looked like new, under bonnet was spotless, and I mean under the plastic engine covers. I notice it mainly when it is cold. It has done about 29k and it had 25k on the clock when I bought it, its a 59 plate.
You mention about not letting the fuel level run too low, what would be the minimum range you would allow yours to go down to?
isx600
January 30, 2013, 4:12 pm
To be honest I'd ignore what your feeling, the engine is just cold. If it was doing it all the time I would get worried or start to find out why. I never go below a quarter tank but that's just me. My lower limit is halfway between empty and a quarter.
jg321
January 31, 2013, 11:35 am
Currently got 33 miles left on my tank!
jeffnat68
January 31, 2013, 11:58 am
Personally I don't use supermarket fuel coz its crap.Well its full of bio additives and stuff to make it more green...Stick a few gallons of shell v power or bp ultimate in and see if it makes any difference...
