[font="Verdana, sans-serif"][size="2"][color="#000000"]Hi everyone![/color][/size][/font]
[color=#000000][font=Verdana, sans-serif][size=1]This is a bit off topic as it does not concern my Monde but a problem with the missis's vauxhall signum 1.9 cdti 150,hoping someone maybe able to point me in the right direction with advice>?[/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]I have a little problem with my missi's car and am hoping someone may be able to point me in the right direction??[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]Vauxhal signum 150 cdti 135k, well looked after.[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]She was driving on the motorway earlier and the car went into limp mode, she limped home and I decided after checking the swirl flap bar was working ok then the next port of call was the EGR valve, I removed the said piece of junk and found it to be partially seized on the spring side and the actuator pin in the electric side was actually partially seized in! [/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]I set about cleaning everything up with wd40 and managed to unseize everything relatively easily, refitted it and took it for a drive, the car drove fine and was no longer in limp mode although the engine light is still on>?? I guess I will need to get the fault code removed from the ecu to get rid of the engine light>?[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]So...... I am on the test drive and the car is pulling well through the gears but I am noticing that the turbo does not seem to be kicking in for long and infact the boost has noticeably dropped........still there but not as much.[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]back home and I removed the turbo boost sensor from the inlet manifold to find it was totally blocked with crud, I cleaned it all off and refitted it, took it for another test drive and found it was boosting better and for a bit longer but still not how I remember it (not drove it for ages!) boosting.[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]My question is....[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]Cant the boost valve wear out? or partially break down? Is there anything else I can clean up that would affect boost?Could a partially sticking EGR valve cause loss of boost? (obviously not sticking now)[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]I had the DPF and ecu command entry removed some months ago also I have just the other day fitted a four hole blanking plate.[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]Many thanks,[/background][/size][/font][/color]
[color=#000000][font=Verdana, sans-serif][size=3][background=rgb(224, 232, 249)]Paul.[/background][/size][/font][/color]
