Full Version: Catalytic Converter Problems
Damian_B
Four years ago I had to buy a new catalytic converter for my Focus. I've just been told I need yet another one. What could be wrong with it? It can't be normal to have to replace the catalytic converter every four years, can it? The car is only 8 years old and has done 90k.
After getting the new one fitted four years ago I continued to have problems with the engine warning light being on. The garage said they didn't know what was wrong with it and basically shrugged it off. This was a garage approved by the Office for Fair Trading, not a totally dodgy one.
I'd be grateful for any advice. I don't want to replace another catalytic converter if it will just go again in a couple of years. Is there likely to be an underlying problem, or could the garage have botched the installation of the last one?
Thanks.
DB
Preee
Could be a few things , un- burnt fuel can cause early fails , or bad mixture of fuel causing it to clog easily.
Also continued use of additives can cause them to fail.
Incorrect fuel/air mixture, incorrect timing, or misfiring plugs are the first things to check
did you have the fault codes read? this is what the engine warning light is indicating..
Moving to the Focus section, its probably better served there!
wase16ll
should never fit a cat till youve found and cured the problem that caused it to go in the first place...if that hasnt been done then guarantee it will keep blowing.
if engine light is/has flashed then the reason it flashed will be instantly stored in the ecu....majority of cars it will stay there till its been read and cleared with a reader..
if it was me, thats first point of call...get it read followed up with an emmission test and readout...
one tip....always remember any fault code is a clue to the fault, not a definite reason for whats wrong.
for eg...code tells you oxygen sensor is not switching...doesnt mean sensor is faulty, it could be a wiring fault, could be injection fault, ecu fault and so it goes on...
finally, be aware that cheap cats are known for failing prematurely....a definite item that fits in the you get what you pay for catagory.
FOCA
Is the car a petrol or a diesel? what engine/ capacity is it?
(i assume its a petrol engine) if its a petrol the engine has to operate at the correct air/ fuel ratio, otherwise it can contaminate or burn out the CAT, without fixing this 1st it will continue to need CATs (as wase has said)
Thats a good piont about sensors etc, the amount of times iv'e read on forums, that someone hase replaced a sensor (sometimes at great cost) because its showing a fault code, to find the new one shows the same code
Also, other things can contaminate CATs, like a worn engine
Full Colour Version: Catalytic Converter Problems
