Full Version: escort diesel - non starter
Ford Owners Club - Ford Forums > Ford Models > Ford Escort Club
drdre20013
i have recently finished putting a new engine in my 99 escort diesel, it took me a little while but it went ok or so i thought, it seems there is not enough fuel getting into the engine for it to fire up, i have checked the pump and this seems ok and the feed and return pipes are fine, there are no leaks anywhere, any other ideas would be greatfully received.
vinnyvangough
Is it a complete like-for-like swap or have you upgraded the engine to a newer/different lump?
drdre20013
its a straight swap for the same engine, i used the same loom so im stumped
hotashel
Have you changed the fuel pump or has it come off the engine that you have put it? Have you tried loosening the injectors to see how much fuel is coming through? If its got a different fuel pump you wont get the immobiliser to turn off. Have you used the manual pump to pump out the system of any air.
You could also try towing the car to see if it will start.
Sorry if you have tried all the above, but having recently done a engine on a pug we were stumped like you are when it would turn over but wouldnt run. We put the original fuel pump off the engine back on and hey presto much joy.
H
Big T
Im having the same problem with my 1995 1.8 van. It turns over, is getting diesel but it just wont start! I cannot prime the system as it dosent have a hand primer on the fuel filter! I cannot hear the glowplug relay clicking but I have turned the engine over untill the battery is flat so it should have started by then! Any ideas!!!!!!????????? :unsure:
Full Colour Version: escort diesel - non starter
