RonaldFord
January 31, 2013, 7:37 am
Hi All. Please help! I recently reconditioned my Duratec 2.0L Mondeo engine. The engine idles fine, revs fine, starts fine and even accelerates fine. However, whenever I depress the clutch at an intersection, the revs fall right down and the engine dies. It starts at the first swing again. Someone told me that the timing was out. I rechecked and reset it. Still the same problem. What else can I try? Thanks.
BigD
January 31, 2013, 5:35 pm
Idle control valve would the likely culprit. Other possibilities; crankshaft sensor (hence somebody telling you the timing might be out), or lambda sensor.
RonaldFord
January 31, 2013, 10:35 pm
Thanks. I will check those.
