qwertymz
February 5, 2013, 5:36 am
[quote name='Stoney871' timestamp='1360006487' post='233140']
[font=Verdana, Arial, Helvetica, sans-serif]If you want to try programming your own new key.[/font]
[font=Verdana, Arial, Helvetica, sans-serif]Try this first-[/font]
[font=Verdana, Arial, Helvetica, sans-serif][b][b]PATS II (Immobiliser) System Programming [/b][/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]This needs the two original already programmed keys to access programming mode.[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Insert the first already programmed key into the ignition and turn to position II[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Turn back to 0 and remove the key[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Insert the second already programmed key into the ignition and turn to position II[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Key programming mode is now activated and you have ten seconds to:[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Insert the unprogrammed new key into the ignition and turn to position II[/b][/font]
[font=Verdana, Arial, Helvetica, sans-serif][b]Allow 10 seconds to pass for the system to exit programming mode. [/b][/font]
[b][font=Verdana, Arial, Helvetica, sans-serif]Central Locking Programming Instructions:[/font][/b]
[font=Verdana, Arial, Helvetica, sans-serif][b]Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.[/b][/font][b] [/b]
[b][font=Verdana, Arial, Helvetica, sans-serif]Remove the ignition key. The locking control system is now in "learn mode" for the next 20 seconds and the red warning system LED should stay on continuously to indicate this.[/font] [/b]
[b][font=Verdana, Arial, Helvetica, sans-serif]During the 20 seconds press one of the transmitter buttons. The remotes signal and code number is learned by the locking module and is indicated by flashing the warning system LED.[/font] [/b]
[b][font=Verdana, Arial, Helvetica, sans-serif]Wait until learn mode times out (20 seconds) or switch the ignition back to ON.[/font] [/b]
I found this on the manual
Is this all I need to program the new (cut) key - or is there another step I require an auto locksmith for?
