FOCA
February 7, 2013, 4:12 pm
[quote name='lottysvdub' timestamp='1360267800' post='234050']
Well it shouldn't do to be honest Jeff.......Most inlet manifolds / throttle body's / cylinder heads etc are made of alloy so your blanking plate should be good..... In fact most new cars have plastic throttle body's and inlet manifolds so I really can not see a problem with yours
Alloy is not aluminium
Aluminium is not alloy
Aluminium is a pure "soft" metal with a realatively low melting point, Alloy means a mixture of 2 or more substances (metals), mixed together to form a "better" substance, often harder wearing tougher and a higher melting point than Aluminium, but lighter than steel/ cast iron
Aluminium is soft and easy to work/ drill/ machine and easy to get/ relatively cheap, if used for EGR blanking plates it has been known to melt through,
This is because the EGR blenking plate can be subjected to high tempratures and pressures from the exhaust, exhaust manifolds are not often made from plastic or aluminium, like inlet manifolds because they would melt, an exhaust manifold has to withstand a much higher temprature than an inlet manifold
If the blanking plate is fitted close to the exhaust, the Aluminium plate is more likely to melt through
If the place you place the planking plate is a long way from the exhaust, the exhaust gasses may have cooled down enough for an Aluminium plate to be safely fitted,
i personally had 6mm stainless steel blanking plates specially made for my car i would not risk the Aluminium melting and dripping into my inlet
