Full Version: 2002 Focus Estate Wheel Alignment Woes
PSABIN8951
During the recent snow I was unfortunate enough to have slid on the ice into a kerb whilst trying to turn a corner.
Despite going at only a few miles an hour, the resulting impact sheared my passenger lower wishbone and of course kerbed my alloy on that side. After a £150 bill with new wishbone fitted and 4 wheelalignment completed im back on the road. However I now find steering gets light at more than 30mph and I have a slight vibration.
I presume the vibration could well be the kerbed wheel being out of balance but what would cause the light steering?
I have a print out of the alignment with the following figures, can someone tell me if it sounds correct and if possible quote what the ford spec for camber, caster & toe-in is please.
My figures are:-
Caster Left front 2.08
Caster Right front 2.35
Camber Left front -1.03
Camber Right front -1.08
Toe-in Left front 0.09
Toe-in Right front 0.05
Total Toe-in 0.55
Steer ahead 0.01
Camber Left rear -2.46
Camber Right rear -2.21
Toe-in Left rear 0.16
Toe-in Right rear 0.21
Total Toe-in 0.36
Thrust angle 0.03
Thanks in advance.
mjt
As your impact was severe enough to shear the wishbone it will have almost certainly bent the alloy. The wheel is now wobbling which is the most likely cause of the vibration and the light steering.
PSABIN8951
It does make sense that possibly the wheel has become bent but then surely the garage would have checked for that when I returned it complaining of vibration & light steering etc as they were well aware of how the accident happened.
dezwez
how did they do the backs the two big bolts that go though the lower arms at the back of car
are normal solid with rust and wont move .I had to burn mine out which means sub frame out dont go there/
thats the only way i could do 4 wheel alignment.but they should only have to do the front wheels as thats were
it was damaged .tyre place i went to only did all 4 wheels because i had renewed all the bolts for wheel alignment
PSABIN8951
As far as I can tell, they didnt adjust the rears at all which makes sense from what you describe with seized bolts etc.
dezwez
looks like you will need a new wheel then not cheap[b] :([/b]
