Bramble1960
February 7, 2013, 9:53 am
Hi, every so often the ignition system seems to die. Works perfectly then the next time I go to start up the amber light flashes and nothing happens. Eventually it will start (seemingly when it feels like it) but a really frustrating intermittent fault.
Have replaced the ignition barrel with no effect, so would be grateful if anyone knows if this is a common fault; if so what's usually the problem.
Car excellent in all other respects.
Nick.
Preee
February 7, 2013, 10:42 am
Sounds more like a loose connection some where which could be a real pain to find , open up your fuse box and check all plugs are secure , sometimes they can get knocked or work loose
Bramble1960
February 7, 2013, 12:13 pm
Thanks. At electronics specialist as we speak; done all the diagnostics etc and I think he's come to the same conclusion as you...
This problem does prop up from time to time on this model / engine but nobody has a definite solution thus far.
