dervtastic
February 12, 2013, 6:05 am
Hi everyone i serviced my 56 plate tdci 1.8 focus yesterday and now the car wont start
I know the problem is the fuel filter, I didnt add any extra diesel when i changed the filter and now there is air in the fuel lines, My question is how will i get it out?
Any help will be appreiciated thanks Adam
Andy H Dibley
February 12, 2013, 6:53 am
Keep cranking it over I think is the best way.
Changed a fuel filters on both my old diesel and petrol Mondeos, for a good 2-3 minutes you had to keep cranking it to eventually get fuel to the bay and air lock free.
dervtastic
February 12, 2013, 7:34 am
Tried for over a hour last night even tried bump starting it to drag the fuel through, Im worried my pump might pack in if i keep cranking it dry,
Theres a nipple on the top and bottom of the fuel filter casing will they be of any use to pump the air out does anyone know?
February 12, 2013, 9:22 am
You need to prime the filter with as much fuel as possible, don't try and start it with no fuel in it - you will never get it going
Last time I done a filter on a 1.8tdci I used a syringe to fill the housing through the nipple on the top till it started to overflow (which does take a few mins as its slow going) but it started quite easily
Mike77
February 12, 2013, 9:52 am
As stated above, it will never start by just cranking over. You could try removing the lid to the filter and filling the housing to the top with fuel, mine worked like this, once running, give it a good old rev, and it should drag any remaining air away. Failing that, you could use a priming bulb,remove the fuel feed pipe, and suck until fuel comes through, replace quickly and crank. Hope this helps.
STEADS
February 12, 2013, 10:54 am
Are sure you have not displaced the o rings inside the fuel line had this on a mondeo reseated and fired up in no time .
dervtastic
February 12, 2013, 11:37 am
[quote name='STEADS' timestamp='1360688087' post='235338']
[/quote][quote name='STEADS' timestamp='1360688087' post='235338']
Do you mean the seal that sits on top of the filter or is there a o-ring on the upside of the cap? Now you meantion this i remember finding a small o-ring under the car im wondering if its fell off will have to check
Im sure theres air in the lines though its not even attempting to fire just turning over.
STEADS
February 12, 2013, 11:52 am
sounds as if you have displaced the small o ring that sits upside the cap where you lock the fuel line to the top of the filter now you will need patience to reseat this and those small instrument screwdrivers if i remember correctly as you look down the line you will see a yellow spiral thats where it sits if you pull one of the other lines off with the o ring in place you will see what i mean will try and get a pic off a spare line i,ve got tommrow.what happens is these o rings should sit in the line/connector but when you release fuel line off top of filter housing they stay on the nipple if this happens you will have trouble staring after filter change like i said had this on a mondeo and took a bit of sussing to find out why it was sucking air .put it back in situ and within a few cranks should fire up hope this helps
STEADS
February 12, 2013, 12:19 pm
managed to get a pic tonight you can see the yellow seating the o ring site below this
dervtastic
February 12, 2013, 12:22 pm
Thanks mate gonna have a look for this in the morning.
dervtastic
February 12, 2013, 12:26 pm
Thanks to everyone for your help.
STEADS
February 14, 2013, 12:10 pm
Any luck getting this started yet
1979Damian
March 3, 2013, 12:41 pm
Hi mate, just serviced mine inc. fuel filter. The cylindrical casing that the filter fits back into has a bleed valve on the top. Although I filled my filter with diesel before fitting I still found air inside & the car would turn over then die. Whilst you crank it you need someone to open the bleed valve. You should hear a hiss as the air escapes & the car should fire up. I cranked mine 4-5 times & it kept dying until I got the wife to start the car whilst I did the bleed valve.
Keep us all posted mate.
Mike77
March 3, 2013, 2:10 pm
Personally think you'll be very lucky if the above works. Normally you would need to use something like a priming bulb to suck the fuel through to the filter, and take it from there.
March 4, 2013, 3:26 am
March 4, 2013, 3:40 am
Should the water drain not be situated on the bottom of the housing? Can't see how you would draw the water out through that valve on the top to be honest.
I believe that valve on the top is for priming
March 4, 2013, 5:04 am
It's definitely a water drain valve.
March 4, 2013, 6:25 am
Hmm, strange one. By the very nature water should gather in the bottom of that housing..
March 4, 2013, 11:21 pm
Maybe it's something to do with pressures etc, possibly pressure makes the water come out first.
