Hi all,
I'm afraid that I'm looking for your knowledge on a problem with my Cmax. Car is 1.8 tdci, 57 plate 51K on clock.
On acceleration, particularly when heavily loaded and in higher gears, there is significant vibration thr' the steering wheel and seats. Also vibrates to a lesse extent when travelling 50-70(ish). Clutch seems fine and no slipping etc. Wheels have been tracked and balanced (3 times for balancing!), no noise from driveshaft when turning and no (unusual) noise when starting or turning off (hopefully not dmf).
It also vibrates badly when braking quite hard from high speeds. Vibrations are worse when braking if wheels aren't straight (particularly steering to the left) and also if foot is on the clutch.
I'm at my wits end with the problem, local dealer very good and helpful but no suggestions! They've checked for play on shafts, brake pads/discs and also checked tyres for deformity, balance etc.
I sold my last cmax when it developed a similar problem but I don't want to sell again, surely I can't have had the only 2 with this problem!!!!! I'm not a 'hard' driver (get 55+ mpg on rural roads)!
Thanks for any suggestions, if you need any clarification please let me know.
Thanks again
Will
