[font=arial,helvetica,sans-serif][size=4]I bought a seat/mirror memory swich as fitted in the driver's door arm rest, from a breakers having another Scorpio 1998 vintage. Using a Ford manual, I obtaineded the pin connections between the switch and the connector it plugs into. That is, which pins shorted when the 4 switch buttons were pressed. Using a meter, I checked the 'new' switch to see if the same pins shorted when the buttons were pressed.[/size][/font]
[font=arial,helvetica,sans-serif][size=4]The problem is, the two checks don't agree, any help would be appreciated.[/size][/font]
[font=arial,helvetica,sans-serif][size=4]Thanks[/size][/font]
