rose5691
February 25, 2013, 12:11 pm
Hello!- I need some help :-(
The boot switch stopped working and every time I put my foot on the brake the boot opens! Amusing and equally annoying. Any ideas please?
John.
February 25, 2013, 1:29 pm
You have probably got a short between the third brake light wiring and the boot release wiring.
Check inside the conduit between the roof and the hatch for split insulation or snapped wires.
durv Cymru
February 25, 2013, 2:26 pm
Had similar when the switch became full of water. Had to swap it for new
February 26, 2013, 3:01 am
MK5! crikey your ahead of the times
MK3 only just out...
start off by starting to take the rubber cover from the handle, I had this issue previously, water had seeped in and started a swimming pool. I took a flat blad screwdriver and began to prize out the grommit and the swimming pool dispersed, it was problem free after that!
rose5691
February 27, 2013, 3:32 am
Yes, my mistake, sorry
So would all this water have some bearing on the boot opening when I put my foot on the brake??
February 27, 2013, 3:48 am
I'd still say check the wiring in the roof conduit to the hatch.
The boot unlocking when braking is is a symptom of a short between the brake light live feed and the boot lock solenoid live feed.
It would point to at least the insulation on the wires being cracked and moisture completing the circuit.
February 27, 2013, 5:17 am
Agree'd, you could have both issues or most likely as Clive said its just the one. To take the rubber out is a 30 second job, so easier to check on the go if you dont have the time immediately to take a look at the wiring, but definitely follow Clive's advice on this one.
