Full Version: Self Fit Reversing Sensors - Bumber Removal
rnem_uk
Hi folks,
I'm picking up a new Focus on Friday and have bought a set of these:
http://www.amazon.co.uk/gp/product/B005IZ8M8O
Has anyone fitted similar, and/or, how easy is rear bumber removal? Are sensor holes part drilled?
Thanks in advance, Rob
Heidfirst
will probably be similar to this http://www.fordownersclub.com/forums/topic/30092-guide-to-fitting-rear-parking-sensors-focus-mk25/
rnem_uk
thanks, hopefully the Mk3 will be just as easy - ie, no bumper removal.
Preee
I have not looked , but i would imagine Ford probably have markings on the New Mk3 as with the Mk2.5 on the inside of the bumper as there are more Mk3 that have Sensors.
minnis
I imagine you will not have to take the bumper off unless you want to make it easier. Slide under the car and check once you've got it, but if theres nothing behind the bumper where you want to drill then don't bother removing it.
