guys,
i have been thinking about getting a cheap android tab (probably a gotab6 or 7 - runs on ICS4) and thought about mounting this into the dash compartment.
I was thinking that the tab can then run the Torque app whilst i drive or even google maps etc - similar function to the Nissan GTR, although i dont know if the GTR displays maps!
I would have to remove my gauge pod and fit this in its location.
It would have to be hinged mounted so that it can be slid into the compartment and when needed you just position this into place.
Possible Issues:
power - this could be powered using the cig lighter socket - but would only work when the car is running
obd2 connection - the tabs dont have bluetooth so would have to be hardwired - obd2 cable with mini usb converter?
gps - the tab doesnt have gps which is an issue - maybe another tab then? it has to be small enough for it to fit into the compartment.
theft - hidden away into the dash compartment - hence the hinge fitting
what do you think?
