Full Version: MY ESCORT
Ford Owners Club - Ford Forums > Ford Models > Ford Escort Club
JAYJAYUK82
Hi im new here and wanted to know if there is anyway i can out if my late (y reg 2001) escort has a heated front screen wiring loom fitted?? How do i find out??
Also how hard is it to change all my dash bulbs to blue led`s and how do i do it??
Cheers for any feedback recieved.
ant1985
hi im new to this but if you take the dash plastic off. remove the 2 screws by the clocks and remove plastic its just clipped on and where the rear heated switch is there should be another loom taped to it and thats the front heated loom. hope this help jayjayuk82
mr.c
You need to take off the plastic covers that run down each side of the front windscreen. to see if the wiring is there. just because there is a plug at the back of the dash for the switch to plug into - that itself just goes to the fuse box. it doesnt mean the wires from the fuse box to the windscreen are there!
Then you have to make sure you have the right fuse box with all the relays and fuses to power it because in my experience i have had mk5 and mk6 escorts there must be 20 different fuse boxes!
If you want to put blue LEDs in i would find a second hand set of clocks, and experiement with them as its not as easy as you might think.
Full Colour Version: MY ESCORT
