Full Version: Ford Focus Front Headlight
DaveC
Hi, hope someone can help. I recently changed the frony headlight bulb on the passenger side of the car and all was ok there but for last week the drivers side bulb also failed. So I got the correct replacement bulb and went to fit it and the bulb will not now work. I have checked the bulb and it works in the passenger side headlight.
It was working ok last week, the old bulb had blown but a new working bulb will not light up. Can anyone shed any light on what what may cause this?
Mike77
First thing to do is check the fuse...
DaveC
Fuse seemed to be ok, is there one fuse for both headlights or seperate fuses?
+1
The focus has seperate fuses for each headlight.
DaveC
ok, will check again thanks
DaveC
All fuses that are in the fuse box were ok. so not sure what else I can check. Any further assistance is greatly appreciated.
salsheikh
Dave, try a multimeter on the plug to see if there is any current going to it.
if you havent got one then just buy one...they ar very cheap nowadays and worth having.
http://www.maplin.co.uk/domestic-multimeter-37279
http://www.ebay.co.uk/itm/Digital-Voltmeter-Ammeter-Multimeter-AC-DC-Meter-OHM-/321058535771?pt=UK_BOI_Electrical_Test_Measurement_Equipment_ET&hash=item4ac094795b
DaveC
Thanks for all the assistance but by process of elimination, once I had located the main fuse box, it was a blown 15amp fuse (fuse no 60).
Full Colour Version: Ford Focus Front Headlight
