Full Version: Focus Mk 2.5 Heated Seats
DazzaRS
having some issues on getting my heated seats to work
i have the ford's own heated switches in place and plugged in
i managed to get heated elements from a 2007 ford focus ST leather seats
i have the wires in places in the loom
i have volts in the intake for the switch but doesnt vary its 0v @ 0 and 12v @ 1-2-3-4-5
i have the ign feed going to under seat thats from the gem module fuse 121 to engine bay fuse box.
any ideas would great full
salsheikh
wish i could help but electrics aint my forte, not since plugging in a battery powered r'c motor into the mains when i was 6!
flew me across the room when i switched it on and it went kaboom!
nazsky786
Can you show pics of the connection to the seats module. And the connections of the seats ,with the module detached. And a pic of your fuse box, remove the orange big plug and show pic of that. And a pic of the fuse box fuses. Hopefully I should find out what's wrong.
DazzaRS
DazzaRS
nazsky786
Is there a fuse for heated seats on the module?
DazzaRS
Yes fuse 121 20a
In place and power running through it
DazzaRS
Iam a electrician I have traced all wires and can confirm there is power under the seat
nazsky786
So all you need to really do is just put the pads in and done.
DazzaRS
No, they wont heat up
nazsky786
Ok check if the pads have a complete circuit as there might be a break in them. Then check if there any power going throught the heated seats fuse. And you need a fuse also for the seat modules. It's a 10 amp fuse. Just rembered. Check the fuse voltage with the switches put on 5. Have you installed the switches if you have do the turn on nilluminate with the headlamps.
DazzaRS
read first post.....
the 10A you mention is the power module supply
they illuminate with dash
nazsky786
Yh read it the switches don't chance temp it's the termo that's in the pad so you should be seeing a 12 for each setting. . Are the pads working have you check if it a complete unit?
DazzaRS
update
i placed in different ford elements and they worked why didnt the recaro ones work? very strange
Preee
I wonder if the Recaro seats are faulty then ?
DazzaRS
will be testing from where they come from today but theres not damage to them
Preee
Does seem very strange , you put a lot of time tracing the wires and testing , only to find the wiring was working , i bet your not happy.
DazzaRS
in a way yes but glad to find out it does work but the issue is the elements that work on my car I dont think they will fit into my seat
DazzaRS
update again... just plugged them into a 07 plate st and they worked straight away.... the gem must control it somehow as the loom is identical
Preee
Very strange , at least you know they are working , so whats your next step are you going to look for an ST Gem or try and modify the seats
DazzaRS
comparing the the pads it really shouldnt be a issue the back part will be spot on.
Will be going to SF car trim in Colchester to have them professionally fitted
Preee
Sounds like a good plan.
DazzaRS
also been made aware that facelift ford focus has a module to operate the elements and pre facelift didnt.
it raises a few questions is the elements differ from the versions of the focus and giving them different part numbers
Just hope you dont get a burnt backside lol my vw ones went faulty once not good when you cant stop and youre bums burning
DazzaRS
would anyone know why a 2010 focus heated seat element for leather is £74 compared to the partial leather is £146
Full Colour Version: Focus Mk 2.5 Heated Seats
