hi any one know the difference in these engines they are both 1.6 16v from 2005 from a focus or a focus c max im after a bottom end for my hxda and have seen a hwda one thankyou
i have answered this but if you want the technical stuff the engines look the same on the outside however the ti vct bottom end has only the same conrod bearings water and oil pump as the standard 1.6 thats all the ti vct has a electronically controlled water oil heat exchanger attatched to the inside of the oil filter housing to aid faster warm up and aid cooling of the oil during normal operating temperatures ,the piston housing the piston pin area are reinforced and the pistons crown thickness has been increased over standard ,there are larger 3.5mm deep valve pockets designed into the bottom end to account for all possible cam timing variations ,the crankshaft was redesigned from an 8 counter weight to a 4 counterweight and the standard symetrical tumble type ports on the intake and outtake were changed to asymetrical ports, the spark plug has been lifted by 1.5mm to make the water galleries closer the head, has different water paths with modified oil circuit and restrictors in each cam gallery, end bearings and cams integrated with a built in vct bridge with increased compression and increased valve llift
the whole engine inside is different it has way different tolerances the pistons are totally different the piston bores have different linings the oil exchanger isnt in the original 1.6 which is required even the wiring to the engine is different as is the ecu so as i said the bottom end will not work you need a ti vct bottom end or whole engine a standard 1.6 will not work as the cam timing will cause the pistons and valves to smash together hence why the ti vct has deeper pockets to prevent this as well as moving various internal parts around
only the same engine will work the hwda is a 100bhp standard 1.6 engine you need the 1.6 ti vct
what about the hdja its a 2010 1.6 vvt out of a fiesta i rang fella today he said its the same engine just any faults they found with the hxda engine have been altered
