Full Version: Front Brakes Binding.
Danny Sayer
I had new brakes fitted around a year ago. Recently the fronts have been sticking and getting very hot. What is the best to do. Get new calipers or is there something else I could do.
You could spend some time trying to free them up but personally I would just replace them.
I had a caliper seize on my mk1 focus, didn't realise until it wiped out the wheel bearing with the heat!
Danny Sayer
Thanks. If it a hard job to replace calipers...
No its not a hard job but you will need some knowledge of the braking system, ie how to fit pads, bleed brakes.
If you do decide to change, get yourself a brake hose clamp - about a fiver. And you will need an assistant to help bleed the brakes also
before changing the calipers check that its not another problem causing the binding like a collapsed flexi brake hose.
Danny Sayer
They have only been sticking on and off. They are ok again now. Not sure what's going on.
Sounds like the slides etc need greased up
Full Colour Version: Front Brakes Binding.
