Full Version: What Is This Part?
hormonedmonkey
The big black bit. ...
hormonedmonkey
Bump :)
TDCiST
Forgive me as I'm on my phone and may not be able to see other info...
What car/model/engine/year??
hormonedmonkey
Focus 2006 TDCI Sport. This is the fuse compartment in passenger footwell. The object keeps buzzing whenever I have a cutting out/will not restart issue.....
I believe it's the main power connection from the engine fusebox.
If you have buzzing I'd say there's a loose connection.
Try pushing the block, you might find it seats better and see how you go from there.
hormonedmonkey
I tried but nothing. I have an on going issue. Its driving me made. In garage tomorrow ££££ :(
To me, buzzing is usually indicative of an electrical short.
It must be a loose connection in there somewhere.
hormonedmonkey
www.youtube.com/watch?v=L64nR70t4pc&feature=youtube_gdata_player"]https://www.youtube.com/watch?v=L64nR70t4pc&feature=youtube_gdata_player[/url]
Video of my issue ▲▲▲
hormonedmonkey
Not sure if thats worked. But the videos called 'Make the Buzzing Stop! What's the problem?' on youtube
wase16ll
could have a bad earth connection somewhere.
hormonedmonkey
Well, its been in the garage all day and were none the wiser. ...
sounds like a relay buzzing to me,have you tried removing and refitting the relay
hormonedmonkey
Still have issue. 2 garages have been unable to find fault. I am very stressed!!!!!!
ajt
As mintalkin said sounds like a relay to me aswell, have you tried removing the relay next to the plug (the black cuby thingy). Or just put your finger on it and see if it is what is buizzing.
It also only happens when you put the plug clamp back on, which seems to be stressing at leasty one of the cables. Try just pushing each wire towards the bulkhead in turn and see if you can cause the buzzing without put the clamp back on.
hormonedmonkey
I've removed it which stops the buzzing.
I'm a bit confused what you mean by; "Try just pushing each wire towards the bulkhead"
wase16ll
this is just a connector, the buzzing will be coming from somewhere else...would be a help if you can track where the buzzing is to start with...highly unlikely its the connector itself.
have you tried pulling fuses one at a time to see if/when buzzing stops [might not just be the one fuse, so just make a note of which and how many fuses]...that way at least you narrow it down to a particular cicuit...
once you know the circuit then disconnect the wiring plugs of destination of that cicuit and see if it buzzes when fuse is in place...
for eg...if pulling the fuse for headlights stops the buzz, then replace the fuse and pull the plug on back of headlight and see if that stops it...if it does then check bulb, if it doesnt then inspect the wiring between headlight/fusebox etc etc..
only way forward is process of elimination...you have to start by finding the exact circuit causing the problem.
hormonedmonkey
Thanks. I now have to wait for it to cut out AND do the buzzing thing as it doesnt always do this
hormonedmonkey
Lots have suggested bad earth?
try the engine bay fuse box if theres water in there or a faulty relay it will feed through
Full Colour Version: What Is This Part?
