Full Version: Injector Removal, Help Needed.
George Lawrence
Morning all,
I got the socket with the window for removing the injectors as suggested. After removing the fuel lines etc the socket will not drop down over the injector completely. Do I have to remove the top half ie where the lines attach ?
your help will be greatfully received.
Cheers George
fish 10
i had to remove all lines,wireing,pull out the injector seals in top of rocker cover,and then i removed rocker cover for easy access,as you need alignment tool to put them back in,quiet an easy job once you get the rocker cover off,hope this helps
Full Colour Version: Injector Removal, Help Needed.
