ptk
March 22, 2009, 8:25 am
at speeds over 50 it changes up and down gears without moving throttle anyone any ideas please
March 22, 2009, 12:12 pm
searching for gears is usually a sign of low oil.
ptk
March 24, 2009, 2:10 pm
oil ok and clean gears work fine at low speeds
rickb
March 29, 2009, 4:23 pm
[quote name='ptk' post='16041' date='Mar 22 2009, 02:35 PM']at speeds over 50 it changes up and down gears without moving throttle anyone any ideas please[/quote]
hi there i had the same problem with my 2000 2.5 auto, under the plastic bottom case of the airbox on the top of the gearbox is a round multi plug just to right or the gear quadrant selector,this had filled up with g/box fluid i blew out the oil and filled the switch on the gearbox with silicon and plugged it back in,its been fine ever since that was six months ago and 9000 miles,its like the overdrive is dropping in and out...hope this helps
ptk
April 3, 2009, 12:10 pm
[quote name='rickb' post='17046' date='Mar 29 2009, 09:33 PM']hi there i had the same problem with my 2000 2.5 auto, under the plastic bottom case of the airbox on the top of the gearbox is a round multi plug just to right or the gear quadrant selector,this had filled up with g/box fluid i blew out the oil and filled the switch on the gearbox with silicon and plugged it back in,its been fine ever since that was six months ago and 9000 miles,its like the overdrive is dropping in and out...hope this helps[/quote]
Thanks very much had a look and its exactly as you said. Really appreciate your help saved me lots of dosh. Must be a common fault
rickb
April 4, 2009, 6:48 pm
[quote name='ptk' post='17992' date='Apr 3 2009, 06:20 PM']Thanks very much had a look and its exactly as you said. Really appreciate your help saved me lots of dosh. Must be a common fault[/quote]
im glad you sorted it....... :
