Full Version: 12V Socket
Goonie99
Hi, my 12v socket has stopped working, i tried 2 different chargers in it and no joy. I only recently bought the car and it did not come with a manual (1.6 LX Focus). Can someone tell me where the fuses are and if possible which fuse it is i may need to change, i just hope thats all the problem is.
Many thanks
k13r4n
My fiesta had same problem and there was two fuses the fuse box is located in the passenger footwell under the glove box and I shall check my manual at lunch time for you to see which fuses and amp rating unless somebody beats me to it
Many thanks
Fuse 39 (20A).
The fuse panel is up under the dash on the passengers footwell.
You need to undo two plastic tabs and the box hinges down.
Pull the board towards you and the hinges at the back will drop into pivot points on the rear bracket so you can rotate the board down for full access.
Goonie99
Thank you managed to replace the fuse, had to try every 20A one tho as no numbers marked on the box. And yes it was the last one i tried!!!
Typical
SeanW
Why would you continue trying if you've fixed it? :-P
Full Colour Version: 12V Socket
