billyboggins
March 22, 2009, 1:54 pm
pretty sure i have a problem with my n/s rear wheel bearing...how much to replace ...is it a diy job?
graham16v
March 25, 2009, 3:11 pm
Its a real easy job if you have access to a press to remove and fit the bearings.
Slacken wheel nuts, choke front wheels and release handbrake, jack up rear of car and support on stands, remove hub nut metal cap, undo hub nut and remove the brake drum, remove circlip and press out old bearing, press in new bearing and install new circlip. Re-assemble.
Whelk8891
March 26, 2009, 4:56 am
[quote name='graham16v' post='16516' date='Mar 25 2009, 08:21 PM']Its a real easy job if you have access to a press to remove and fit the bearings.
Slacken wheel nuts, choke front wheels and release handbrake, jack up rear of car and support on stands, remove hub nut metal cap, undo hub nut and remove the brake drum, remove circlip and press out old bearing, press in new bearing and install new circlip. Re-assemble.[/quote]
...or if you don't fancy the hassle, I got a rear wheel bearing replaced at a small local garage for £65. Although Ford would probably charge you 4x that.
