Full Version: Clutch Pedal Fails To Return Fully Until Car Has 'warmed Up'?
michaeljohngoff
Hi Folks, I've recently bought a Ford Mondeo 2.0 TDI LX 115 2001.
I was hoping somebody could help me diagnose a fault i have with the clutch pedal which fails to return fully when the car is first started? after 20 minutes of driving the clutch pedal starts behaving better and selecting gears becomes easier.
It doesn't seem to be losing hydraulic fluid and the longer i drive it the better it gets. Any help would be much appreciated as i'm currently fighting to shift smoothly.
Michael
FOCA
The clutch shares its fluid with the Brake master cylinder resovior - keep an eye on the level and see if you are loosing fluid - its possible the CSC (concentric slave cylinder) is leaking and you may not see this because its inside the bell housing (part of the gearbox casing)
  Any air (at the CSC or elsewhere) entering the system may cause "loss of pedal"-  if you pump the clutch pedal a few times and it becomes easier to put in gear it could be it needs bled    the Master cylinder may be leaking too or, simply a leak in the line/ needs bled (the cheapest to fix) - if its the CSC the gearbox needs to come out - a big job/ labour intensive (expensive)  - a stronger or extra clutch pedal ruturn spring may help to keep it going a bit longer
michaeljohngoff
Ive tried pumping the clutch pedal a few times but it doesnt make a difference. 15 minutes into my journey the clutch pedal has full movement but still feels limp to me and getting into first and second is especially difficult (possibly because i use the clutch more when initially pulling off than when shifting from third / fourth / fifth?). It's a real pain at traffic lights when you are contending to put the car in gear.
I'll check the reservoir level personally but im told by the previous owner that it isn't leaking (i'll verify this weekend). Would a problem with leaking mean i lose braking efficiency aswell though? as It ssems to brake positively enough.
I currently write with zero knowledge of master / slave cylinders and gear boxes but I am leaning (from what ive read) towards a faulty slave cylinder. I have a mechanic friend who plans to help me this weekend but any information on bleeding reservoir / checking slave cylinder would be greatly appreciated if only for reference when we do carry out the work.
michaeljohngoff
Coould there be multiple issues aswell I.e. Loss of gearbox oil?
flying clutchman
although the clutch and brake systems share a resevoir they are seperate in every other way. The resevoir is split internally, so losing fluid in the clutch will never affect the brakes. The problem is that air is getting into the system The reason it improves with use is because the floating valve fitted to the concentric slave self bleeds  as you use it. Trying to bleed it will be a waste of effort. It's very difficult to try and work out which cylinder is the culprit. The master cylinder is the much easier to change, as the gearbox needs to come out to do the slave.
michaeljohngoff
So should I change the master cylinder and then check performance. If there is no improvement then change the CSC?
FOCA
It all comes down to money-
- how much the car is worth/ how much you are prepared to spend on it/ do you intend to keep it for a while longer etc etc
It could cost £400 on labour to remove/ replace the gearbox (nessesary if the slave cylinder needs replaced) - if you are doing this, because of the high cost of labour doing this, it is recommended that you replace the DMF, clutch as well (upto about £400)
Now you may be able to do the work yourself, know someone who could do it or get "mates rates" (eg, labour for £250 or less) and you could just replace the CSC (slave cylinder)
After replacing the master cylinder, you may find its the CSC after all
Another option is just to put up with it as it is at least for a while
michaeljohngoff
I do plan to keep it for a few years yes. I also do like to get my hands dirty and acquire more knowledge regarding the mechanics one job at a time. Jobs i have done in the past on other cars include - oil sump change, New Rear shocker springs, exhaust system, Hand brake / rear drum / front disk brakes pads. The engine and transmission etc i havent got any working knowledge of though. I have a mechanic friend that will endeavour to help fix this problem and a couple of other niggles aswell.
I may just replace the slave cylinder for now depending on finances. A friend mentioned that there is a hose that connects the master cylinder to the slave cylinder, at least i think that's right (although im unsure of the exact steps). He plans to change this hose for a new one that also has a 'compensator' in the middle of it. We shall bleed the system this week perhaps and see what happens from there.
I plan to carry out all work myself though (with the aid of said friend) but i like to to be better prepared in my own mind going into the weekend.
stooge75
Mate,this is a recipe for disaster if you dont mind me saying. forget about hoses etc. you need to check your master cylinder(behind pedal-any signs of fluid?),& bleed the hydraulics it 1st.If you dont know how the system works how are you going to know whats wrong? Dont rely on mates.I learned that the expensive way years ago.(and when it ALL goes wrong,you cant blame him cause he's a mate,& is only trying to help you). Take the car to someone that knows about clutches & has changed a lot o em. You'll save doe in the long run
michaeljohngoff
I plan to learn the system as I enjoy the challenges of fixing / maintaining my own vehicle. We plan to inspect the system this weekend and if necessary be prepared to swap the master cylinder and hose. If necessary we shall attack the slave cylinder next weekend.
It Is indeed a recipe for disaster but I thrive on the satisfaction of diagnosing and fixing all mammer of things. I like to tinker and it cant hurt to gain knowledge of such systems. I hear that these things can ba complex in nature with many parts to contend with but despite my inexperience I am both capable and methodical (I hope).
stooge75
Kudos to ya for trying then. Its not a complex system really though. Can only be either a problem at pedal,at release-bearing/slave,or pressure plate. Hope its not your clutch tho as quite expensive and labour intensive,unless you have access to a ramp.
ive just read over your post agin. i have a feeling you have 2 probs there. 1.your clutch pedal and 2. bad transmission prob. just noticed its a 2001 mondeo yeah? whats the mileage? if the cars been driven like that for a while it would take its toll on the synchros especially 1st and 2nd. are they the worst gears to select ?
michaeljohngoff
2001 ford mondeo estate, 177k. I would say that first is the worst followed by second then third etc etc.
FOCA
The 2.0L 115 TDDIs estates are the best ones, runs on anything, estate practicality and room for 5 adults in comfort and their luggage, + the TDDI does not use the (rubbish) delphi injectors used in the TDCI
I have heard of them going to 300+k so yours is just nicely run in now :)
Just keep replacing the consmables (tyres, brakes, filters, EGR valves (or fit a plate!), DMFs (or upgrade that too) - and it keeps running!
It can even be souped up untill it has more power than an ST-TDCI! (allegedly)
michaeljohngoff
We have replaced the clutch master cylinder and bled the system and it seems to be okay for now! I'll see if it stays air free in the next 48 hours. Fingers crossed or were going to being tinkering with the gear box and centric slave cylinder.
Clutch pedal returns for now and I'll comment on gear shifting in the next 48hrs.
stooge75
good good. much was your master cylinder.if its ok for now,chances are it'll be ok tomorrow hopefully. someone deserved a bit of luck around here.glad its worked out for you.
michaeljohngoff
A friend was owed a favour from a garage and thus we we raided a ford mondeo that he was breaking, as such we got the parts free. As for my mechanic friend I built him a pc for racing simulators and so labour free. Clutch pedal seems fine. Can still be hard to select a gear though sometimes. I'll probably get the knack of it.
stooge75
sounds like your synchros are still a bit shot still though. The mondeo boxes (6 speed) are terrible til they warm up. I have a brand new box in my car & even that aint as good as a VW/skoda etc transmission. dont know what ford were thinking when they designed it.crazy. Even the head mechanic at Ford said "Theyre not smooth operating til they warn up". tut tut
michaeljohngoff
May I ask what synhcros are? Would it be worth swapping the box? (5 speed). The previous owner said its never liked going into first! 1st and 2nd are now the only troublesome gears I would say.
stooge75
yes it does sound like synchro issue,but the 5 speed is supposed to be a better design of transmission. your synchro's are what help select a gear(it uses friction to enable the gears to engage). if it IS synchro issue,you'd be better putting it into get repaired,but make sure that the specialist preloads them properly or you'll get the same issue all over again. I bought 2 used gearboxes that both had same synchro problem. its always 1st/2nd gear syncs that go 1st cos theyre most used gears etc.
Now if your car has been driven with a slightly dragging clutch,which i DO think is possible due to your clutch pedal issue(master cylinder),then it degrades the said synchros much faster as the clutch cant stop input shaft spinning completely,& gears are hashed instead of synchronising.Hows your reverse gear? sometimes a hard 1st / reverse gear symptom can be a sign of a DMF going,but not always. The only way to tell is by removing gearbox opening it,& stripping it down.(very time consuming & specialist job).
All depends how much time and money you wanna spend. cant remember if your car has the linkage /cables etc. Have you tried adjusting the cable at gearbox end? you might have the box that needs the special tool thing though. worth a try though. there must be a guide somewhere online for doing it. Mines is just a case of putting into 4th gear at box(with the tower),getting someone to hold gearstick agains the stop in 4th position,then unsnap the clip on selector cable,then snap it back into place.and voila
michaeljohngoff
Reverse gear is fine. 1st and 2nd are ok 80% of the time. 3rd and 4th 90% and 5th is perfect. I think i'm going to live with the gearing for now. I would say that it gets better after 10 - 15 minutes driving though aswell. I may check gearbox oil.
Thanks for your feedback guys - Much appreciated.
stooge75
Think its your synchros. As i said i have 2 boxes lying here with exact same problem. My personal advice is dont change gearbox oil. On both occasions i did it, it made it much worse, especially with the ford box oil. Its no good for worn syncs!
On one box i was told by tranny specialist to put 5-30 engine oil in it, but it never helped at all. Only thing u can do is repair it & its NOT cheap. £400-£600 total.
michaeljohngoff
I think i'm going to take that advice (don't change gear box oil). The car is still perfectly driveable and i would even go as far as to say its enjoyably so (if a little nuanced!).
thanks again.
