Full Version: Mondeo Tdci Injectors Question
martinstone
hello, the injectors supplied to me are code 301z the ones removed were 501z am i correct in thinking the nozzles are too long and wont work on my car? or is there away around this? my pump failed and as everyone says  replace injectors also but is there anyway my injectors could be saved as they were only replaced months before at a expensive cost, no metal shards were found anywere in the fuel system could i have been lucky?
If it were me I would risk using the old ones. You might as well chance your luck and save the cash.
stooge75
have you had the old 1's tested??
callumthemechanic
If there were no filings you should be ok but when a pump goes usually you replace the tank fuel lines and injectors but you might be lucky
Full Colour Version: Mondeo Tdci Injectors Question
