Full Version: Mk3 Mondeo Bonnet Trouble
Neil101
Think this might be a common subject but i haven't come across an answer yet
If i press down on the bonnet whilst turning the key to the left (before then turning to the right) it sometimes 'opens' but most of the time it feels like the key will snap.
Pushing down doesn't always help but is better when pushed, have had a spare standard key cut to avoid damaging the expensive remote keys.
Have lubricated the inner 'lock' with wd40 & tried greasing the end of the barrel going into the vehicle.
Any help appreciated.
ppeter7
yes there is a common fault with these i guess you tried it with bonnet up but lock shut as if bonnet was closed???..it could be either barrel try wd40 into the barrel.it could be the link bar or lock itself hope this is some light on subject
Steelie600
very common problem on mk3 and mk4 mondeos
Piss poor design imo and they seize up like mad, You can free them off but its only a matter of time before they do it again, and theyre not user friendly either cos they are sealed units so to open them up you have to break them!! Frigging throw away society I hate it!! Why cant parts be serviceable!! Itll be cheaper for everyone then!! ARRGGH
Anyway I digress, get yerself to fords and buy a new one as thats the only way to cure it properly. Cost is around the £60 mark for the complete assembly
BigD
Do not put WD40 in the lock, as it is not a lubricant - its a penetrant.
WD40's lubrication properties are very short-lived. When that wears off in just a few hours, the WD40 will be sat in the lock, collecting all the dust dirt and filth that goes anywhere near it. The upshot is that your problem will soon return and be 10x worse than before.
To lubricate a lock i'd recommend a light oil or heat resistant PTFE lubricant.
FOCA
There once was a time when WD40 was used (to try) to fix everything - how times have changed! :lol:
ponsaloti
Get a new none-chipped key cut. This often cures the problem.
Full Colour Version: Mk3 Mondeo Bonnet Trouble
