Full Version: Overflow Problem
drbabbers
All,
I am having an intermittent problem with my Focus. What happens is when I put diesel into the car, some diesel will then be dripping out of this overflow pipe. It doesn't appear to matter if I fill the tank, or only half fill it. In fact recently I put about £20 worth of diesel in and it still did it! So it can't be that the fuel tank is full.
I rung my local Ford garage and they were stumped and said they can really only start with diagnostics and take it from there.
Does anyone here have any ideas or advice?
Dean
salsheikh
Dean, the only thing i can advise is get a funnel from Ford and slowly fill diesel into your car. I know that if you overfill it then it will drip out but yours is wierd!
see this thread for the funnel part no and pic:
http://www.fordownersclub.com/forums/topic/34977-fuel-funnel/
drbabbers
Thanks for the reply. It is most certainly a strange issue! So if I get a fuel funnel I will then fill the car from a can and not a pump? Also what does this prove?
Thanks!
Dean
salsheikh
no mate, you insert that funnel into the fuel neck and then slowly ad fuel into your car using the pump. the funnel will stp the fuel from dripping out from underneath.
drbabbers
I used the funnel this morning and no fuel split out the bottom of the car!
So does this mean I use the funnel always from now on? Is this not something I can get fixed?
Thanks.
Full Colour Version: Overflow Problem
