Full Version: Need Help
STRETCH2009.
hi guys i bought a 1.8 tdci sport focus but when i get in it strat the engine some times there is no revs at all then it will kick in i took it to a garage today and the codes come up are 0336  1632  0100 and 1260 anyone no what they mean and do u think it would b to do with any of these the problem thanks guys im new so need a bit of help lol
FOCA
These are what the fault codes mean -
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P1632 Smart Alternator Faults Sensor/Circuit Malfunction
P0100 Mass Air Flow Circuit Malfunction
P1260 THEFT Detected, Vehicle Immobilzed
I would check it has the correct (silver calcium) type of battery fitted, and look at the alternator 1st, as voltage changes/ fluctuations can sometimes generate spurious fault codes.
STRETCH2009.
i went to the garage today cos the light come bk on and the only code that come up is p0100 air mass so dont no if i should get a new one or c if the pin is broke like one of the guys had on here
FOCA
Voltage fluctuations can sometimes generate spurious fault codes -
(if the cars' battery voltage is wrong you can get false fault codes from sensors that are really ok, or one code/ fault can cause more fault codes- like a chain reaction)
Look at the MAF sensor connector and if no pins are broken, clean the connections and just put it back on, it might just be a loose/ bad connection (and save you paying for a new one) - the actual sensor is delicate and must be cleaned carefully
STRETCH2009.
ok when i do that do i have to go and get the eml turned off b4 i will c if that worked is there anyway of seeing if it is the maf its self
FOCA
Unless  the MAF is obviously phisically broken or damaged its difficolt to tell, you can buy a code reader for about £20 that you can read your codes and reset them as often as you like (F-super, available online - you will need a windows pc with a USB port)
Just because the Air mass flow is "out of range" / "circuit malfunction",does not nessesarily mean the MAF itself is faulty
Some mechanics disconnect the MAF and drive the car around to see if it makes any difference
Do you have a multimeter or can you aquire one?
STRETCH2009.
i dont have a multimeter but yes i can buy one and i was thinking of unplugging the maf and driving it to c if it does anything or stays the same what should the volts b on all the pins if i get a multimeter
Full Colour Version: Need Help
