Full Version: Oil Leak Out Of Of Wishbone
Avenger1978
Today changed my struts and looks like i have damaged my wishbone rubber , i forgot there sealed with oil, so next question is... do i need to put a new wishbone arm in asap or is it ok to drive about with it like that and what would i have to expect with it broke..., Vibrations? because  i can now feel vibration coming though the steering wheel and feels like my drivers side wheel is really unbalanced like it needs balancing or something or could that part be because i took off the anti roll link bar and i need to buy a new one has old one has had it.... i just cant see wishbone rubber making my Tyre shake/unbalanced. and another thing when i freewheel/coast the shaking goes but soon as i accelerate vibrations come back
Any help on why my wheel would do that would be a great help thanks
EDIT... Also i can feel the vibrations though the floor after a long motoway journey (i feel like i have been jack hammering when i get home lol)
Avenger1978
ppeter7
ok check springs are sitting ok in shocks.also recheck all bolts are tight after road test.deprnding how bad our shocks are they might have worn the tyre where it could have been skipping down the road which would cause a tyre inbalance and vibration.if you split the lower arem seal then it have to be changed for a new 1.easy option would be to get lower arm ball joint about £20 to £30.you might need to grind off the old rivits from lower arm as replacements are bolted on.the lowr arm replacement means having to drop subframe as i done mine last year bit of a pain hope this helps
Steelie600
What wishbone seal??? Shouldnt be ANY oil in a wishbone. Unless you mean the ball joint gaiter. Then in that instance yes you need to fix it and fast. Dirt ingress will kill a ball joint toute suite.
Wheel shaking but stopping when you let off is generally the inner CV joint losing 1 or more of the needle rollers. You say youve had the ball joint apart. This is likely to be the cause. Stripping and cleaning the CV joint, and re-fitting the needle roller thats fell out will more than likely cure it. Dont forget to re-pack with fresh CV grease.
Worse case scenario is to replace the driveshaft. Also possibly the easiest unless your competent that you can rebuild the inner joint correctly
Avenger1978
sorry should of been more clear there is 3 bushs on the wishbone the big round one at the back is a hydro bush (I think thats what their called) filled with oil and i have broke it pressing down on the wishbone to hard and its pop like a balloon so now no oil in in the bush
stooge75
i am sure ididnt have to remove subframe to get my wishbone out,
Avenger1978
I hope not im going to put a new wishbone in this weekend
Steelie600
Ahh reeto yeah if you've burst the hydro bush then youll need a new one. TBF tho ive been pretty brutal with them and never damaged one, It must have been close to failing in the first instance. It may cure the vibration under acceleration, if replacement doesnt cure it then itll be the inner cv joint.
stooge75
lol.same here. ive hammered em,pushed/pulled em & never had 1 burst. why cant my car have the wee faults like that instead o PCM faults etc
Avenger1978
now its making a noise like if i turn or set off i hear a noise like some think isnt fastened properly like 2 metals hitting each other kind of noise so i had it all off again last night even took the suspension back off every thing looks ok and i could not make that noise so i am hoping its the wishbone damage making that noise sounds like its coming from there with the hydro bush broke wishbone must be moving about now and making that metal banging noise.
I have never took a wishbone arm off a mondeo how hard is it? i sprayed all the nuts and bolts last night just incase lol
stooge75
its dead easy mate. even easier with a windy gun lol
Steelie600
wishbones are easy peasy. Just take yer time and work methodically
Avenger1978
i have done wishbone the banging noise as gone.. back bush was a bit knackered with no oil in it, but the vibrations are still there, so could it be the driveshaft whats doing the shaking/vibration  this  only started doing this is when i changed the whole suspension on that side but the shaking/vibration only came on gradually like got abit worse over a short time.. so whats the chances the drive shaft is doing the violate shaking/vibration?
EDIT..Also will a driveshaft off a mondeo estate 2.0 tdci 115 bhp 5 speed fit my car which is the 6 speed tdci 130bhp hatchback thanks
Steelie600
No the splines are different.
And TBH you may find that youve strained the inner joint too much and a roller bearing has fell out. Its easy enough to pull the boot back and rebuild the bearings. Youll find the errant bearing inside the boot when you slide it back.
All youll need is some CV joint grease and a couple of cable ties to do the job, and a shed load of paper towel to clean the old grease out so you can see what yer doing. A lot cheaper than changing the shaft,
Avenger1978
when i pull the drive shaft out will oil start coming out? of the shaft hole? what do i do ? let all come out and fill  the gearbox back up afterwards?
I no when i was putting hob back on to the driveshaft, the middle part with the rubber protection thing around part of the  shaft had alot of play in it moving backwards and forwards it moved that much i thought i was going to break it...i will give that ago tomorrow see if i can repair it then if its that lol
EDIT a friend of a friend had a look at my car hes saying its shudders when accelerating, makes a loud clunk when changing gears and the car vibrates at any speed, it is coming from the drivers side so it is the driveshaft needs doing, something about the U joints are warn but as i was at cricket when he came i didnt ask him in questions..my question is will i need to still change the driveshaft or can i change the u joints.. which i think you cant but who knows lol
Avenger1978
Avenger1978
i have just took the driveshaft off ( im getting quick at taking it all apart now took me 30 mins lol) and i did what you said pulled the boot back alot of grease in there anyhows 1 of the round things was still connected to roller bearing joint and the other 2 was still in the other big part so have come off but looking at it close 1 of the round things was missing its inside and  that was still on the roller bearing side joint if you know what i mean so now i have 4 round things 2 are ok 1 i think push's in to the other to make 1 so is it still worth rebuilding if one of the round things as come apart like that
Steelie600
yeah it should be fine. basically you have 3 pins sticking out from the end if the shaft. and 3 big wheels that sit on those pins. Those wheels rotate on roller bearings which are cylindrical. Basically clean it all up so its spot less.
Then fill a wheel with rollers and then shove some fresh grease in there and put it on the pin, do the same for the other two.
the fill the drive cup with the rest of the grease, and then sit cup on top of the rebuilt shaft assembly then using some cable ties fasten the boot back up and refit to the car.
Avenger1978
Thanks i will give it ago now
After tring to rebuild, 1 of the round things bearings had seen better days i could not get the small wheel back in to the large wheel it looked broken so went to scrappy and got a shaft so took it all apart like you said, washed steamed it greased all the wheels up looked alot better than mine filled the cup up with grease and put the roller bearings in back in and tied all the boot back up now its running fine with no vibration, no clucks from changing gear now the car is back to smooth so at least i no how to rebuild a drive shaft now lol and a big thanks to steelie600  :)
Full Colour Version: Oil Leak Out Of Of Wishbone
