Full Version: Some Damage Advice
GerrardLFC
Hello,
A few days back I was driving along a notorious road in the welsh mountains that has a lovely little stubborn speed bump over a hill which I happened to hit at about 40 (bare in the mind the limit for this road is 60 and the bump appears from nowhere once you go over the hill) thanks to hitting this bump I've completely smashed the plastic which is under the car and I'm assuming is there to protect the engine?  It also managed to knock the tracking out a tiny bit.
Once I got back home I noticed that a massive piece of what I could only assume is sound proofing was missing 2 bolts and was hanging down from the car, I will be getting this re-attached in the morning.
Is this plastic important or should I not worry about it too much?
I have a Focus Zetec 2012.
The plastic protects the engine keeps crap off reduces engine noise and should be replaced if it knocked te tracking out it may have buckled an alloy as well
JayTDCI
Sounds like you hit the under tray to me, best to get balancing and tracking sorted, if you've noticed vibrations on steering wheel.
FOCA
You should complain about that bump - i wonder how many others that has happened to?
Andy H Dibley
Lost my under tray when I hit a deer just before Christmas, first car I've owned that's had one. They mainly provide protection from gravel roads and splash protection from big puddles. Been driving without one for 6 months, no issues yet. First car I've had with one tbh.
The only bit that is semi important is the air dam either side of the from AC condenser, that kinda focuses air onto it. Not a huge pain if its not there, just handy.
ffz
I might be talking out of my backside, but is there not some aerodynamic benefit to this panel?
FOCA
Yes, apparently it tidys up the air going under the car, some call it a "fairing" its effect is probably quite subtle though,
i was doing some work under my car last year and never bothered to put it back on (its extra weight, anyway) the only difference i notice is the engine is louder and i get a bit more clearance over speed bumps, i possibly get a lttle less traction
some cars came with them fitted, some not
i think it may be an expensive item new and hard to track down one secondhand for a 2012 car
Andy H Dibley
Not really, what you might be thinking of is the same panels that racing cars have fitted. These panels are there to speed up the air flow under the car, from the splitter at the front to the defuser at the back. It makes the car like a reverse airplane wing and offers down force.
For this to work though the car needs to have an almost uninterrupted flat surface from front to rear and needs to be travelling at fair old speeds. Somewhere in excess of highest speed limit for it to be of any use.
FOCA
I disagree, road cars have to travel through the air too, and even though they are not designed to produce downforce,  modern cars are aerodynamically designed to slip through the air to get a good fuel consumption, the undertray looks like it fills the space between the bottom of the front of the car and the front of the floorpan where it seems to line up nicely, although there are parts sticking out like the suspension, the exhaust, fuel tank and other components are tucked away out of the airflow
The undertray looks like it has aerodynamically designed vents in it  and if you thing about it the air going under the car is going as fast as the air on top (eg, if the air on top is doing 70mph, the air underneath in doing 70mph)
Areodynamic drag is a square law - that means doubling the speed increases the drag by four times,(eg - there is FOUR times the aerodynamic drag at 70mph than at 35mph ) that is why the fastest Veyron had to have the power increased from 1000Hp to 1200Hp just to get a few more mph to retake the "fastest car" catigory - James May drove it but was not allowed to explain the square law - the producers wouldent let him, they thought the audience would not understand it - so he had to say the air was "thick" like treacle at high speed, instead
you can consider the undertray like the fairing on a motorbike, it too, does not produce downforce or does not go all the way to the back of the bike, but helps the bike slip through the air more efficiently  - if you took the bonnet off, do you think that would make a difference to the aerodynamics? its like a bonnet, but underneath instead of on top!
It is hard to say how much of a difference the undertray/ fairing makes, remember these cars are also designed to run at 100mph+ speeds on Autobahns, where it could be very signifcant, but even at 70, it could make a difference
I remember reading that over 40mph, aerodynamic drag is important, at what speed do the active grill vents close?
I might put mine back on once ive fitted my new bottom engine mount and q-rusted and hammerited under the car - it only weighs 2.4kilos!
GerrardLFC
I have a sneaky feeling it's messed the shock absorber or suspension bracket on the passenger side of the car, when I drive along I hear like a spring type noise like an elastic band it reminds me of.
I think I may have to get it repaired via insurance claim :(
FOCA
You could have broken a spring.  Its just a matter of wieghing up the cost of doing it/ the exess and if your NCD is protected etc - i wonder if the peple that installed the speed bump could be liable for your costs?
jameso
hi
first things first you say you hit a bump in the road have you had a good look underneath the rest of the car because you could have damaged a lot more than you think ie brake pipes fuel lines best option take to a bodyshop that give a free estimate and then you can tell best option
GerrardLFC
hi
I've had it checked today, no damage as such.
I guess this is a case of living and learn, some people learn a life lesson and don't get to drive away like I did :-)
jwc28
Hi folks, I have a damaged air deflector (the plastic tray directly underneath air con and coolant rads) its not the main tray underneath the car. I have ordered a new one but was wondering if anyone else has removed/fitted this and if its easy and should I look out for anything? Many thanks. P.s focus mk 2.5 2011 model.
i know the panel your talking about mate,
Luckily a member of the forum called Ryan is upgrading the intercooler on his mk2.5 focus this Saturday,
He's also creating a guide on doing it,
The same panel your seeking guidance on replacing will be removed when removing the intercooler,
Here is a link to Ryan's thread see the last post on the page linked here says he's fitting Saturday with pictures,
Perhaps pm him for pictures or advise before he does it, I'm sure he would be happy to assist:
http://www.fordownersclub.com/forums/topic/59271-tdci-intercooler-question/page-2
Also here's the one image I have of that part, seems to be gripped to the front bumper using a bolt pin with spring clips,
Nothing a long nose pliers wouldn't remove,
Also worth having a can of WD-40 to hand, spray and let it soak in to bolts makes them easier to remove.
troy45
That'll be the front bumper undertray :)
If it's got the same spring clips as the ST version you can help release them by getting your hand over the top of the panel and pushing up the raised metal tag that sticks up from the clip. These are on left and right side where the panel meets the bottom of the bumper. You might find there's also a small torx screw going into a clip at the middle of the panel where it meets the bumper, just take care with this as the screw can be rusted tight and cause the mating clip on the panel to spin round instead.
jwc28
Thanks. Troy! Thats exactly the panel. What i can see so far are torx bolts etc. But where it attaches to the buttom of the painted bumper its 3 phillips headed screws. But its these plastic looking ones. Are they expanded on the other side? (im a novice) and ones missing!
troy45
If your model of Focus has deflectors either side of the intercooler these can have plastic scrivets holding them to the bottom of the bumper, could be the same for the centre fixing too instead of the torx screw and j-nut. Then there'll be a number of Torx 30 screws holding the undertray to the bottom of the radiator cradle and a couple at the edges going into the wheelarch liners.
Can do the ST one with my eyes shut I've had so much practice but not 100% certain if it's all the same on the other models too.
jwc28
Thats very accurate troy. Sounds same as mine. Question is can u take that tray off without removing the main engine tray? And what is a scrivet? Ones missing. Scrivets easy to remove?
troy45
Not 100% certain if you can get the bumper undertray off on it's own, think you'd really struggle for space to move it out of the bumper with the main undertray still in place. You may be able to undo the front fixings of the main undertray enough to let it drop down, without having to totally remove it but I'd say you're better off removing it fully as the rear screws alone can go into different fixings which aren't as secure.
Scrivets are plastic screw/rivets like this
Ianb
Might not matter on some bigger cars, but there was a guy I was chatting too who had a van as his normal vehicle, but when he went on holidays and took ferries he used a small car he had. No idea what it was, but it had an engine that looked like the next step up from a lawnmower, belt/pulley gear box etc. Nice guy to chat to, he said the speed in it was pretty awful but it was cheap to run and take on ferries, but he said it didn't have that 'fairing' so he made one himself out of some lightweight plastic etc and it actually gave him about 5-10 extra mph... (I think his top speed without it was like 50mph anyway)..
..so that being said, you might find that with it your MPG is greater as your car won't need to work as hard to reach cruising speeds...
jwc28
interesting story. Yeah many people would just do without but it must be there on our production cars for a reason. Otherwise ford wouldn't have went to the expense of design and cost. :)
troy45
Think it's pretty important on some cars where the crank pulley would be exposed to damage from road debris without an undertray.
While you may not notice a small difference in mpg you'd definitely notice if the crank pulley took a thump and the valves decided to get too intimate with the pistons. :(
jwc28
Haha troy..........the main ford dealer supplied me with all the bolts and clips they thought I'd need cos I like to renew fixings as sometimes clips etc are only good for applying once. Anyway they didn't even know about any scrivets so supplied me with none! Sometimes u know ur own car bette than the dealer. Luckily u can buy the same scrivets in halfrauds for couple quid.
Full Colour Version: Some Damage Advice
