Full Version: Access Rear Light Bulbs On Mark 7
Ford Owners Club - Ford Forums > Ford Models > Ford Fiesta Club > Ford Fiesta Guides
robberrabbit
1. Open boot and remove the 2 screws attaching the light cluster to the back of the car. A small flat blade or a torx 25 screwdriver will do it.
2. Inside the boot pull back the side carpet behind the cluster. Starting at the boot-latch end ease out and pull back the carpet all the way to about halfway back towards the rear seat. There are no clips to break it should come out pretty easily
3 You now have access to the back of the light cluster. There is a small rectangular hole  there and just inside that you will find a long wingnut. Unscrew and remove
4. The cluster can now be eased out. There are no clips to break, just 2 push studs on the outside of the cluster which can be pulled out of the back of the car.
5. Before removing it too far disconnect the wiring block at the back so that the cluster becomes free.
6. The bulbs are held into the cluster by two clips - press those back and the bulb section can be removed
DanGersFord
Moved to fiesta guides try and attatch some pictures :)
AdamC11
Do you have the link of where this has been moved too?
iNath
Right here :p
AdamC11
Do you need to remove the wing nut before accessing the rear bulbs?
iNath
You sure do.
chrispage1
Probably worth adding that not sure there is really any point in having the wing nut on? I took mine off and left them off and they have been fine since.
