Full Version: Boot Trouble
stokerfatlad
hi all
      iam a newbie i have been a member about 5 months and i have a 2 litre desiel , i am hoping someone can give my good advise on my boot lock i have replaced  the lock and had the catch micro switch checked the rear fuse No 5 and still cant get the boot lock to work iam at a loss to where to go now as anybody had this problem?
gregers
check for broken wires in the rear door gaiters.
Also check that there is no water in the switch area underneath the rubber cover.
stokerfatlad
hi guys
           thanks for your ideas i have checked them out but still no joy  got any more thoughts
cheers
  dave
when you try to open it, do you feel the switch click? do you hear any noise?
are you able to force it open from the inside (I believe there is a handle in the boot somewhere?
stokerfatlad
hi there is no noise from the switch but you can feel it and i did remove it and checked the switch was letting currant past when operated and it did, there was no handle on the inside but i have fitted a cable to the catch so for te monment i can open it from inside.thank you for your thoughts  cheers dave
In that case, it might be a catch issue.
Are you able to force the boot open (not sure if the SMAX has an inside handle for emergency release?)
stokerfatlad
hi the catch is working ok and the s-max has,nt got a handle inside the boot but i agree they should have one
i have decided to try a new micro swicth on the handle as mine may not give the correct volts i let you no how i get on it may take a week as iam in germany for a week
cheers
dave
Enjoy your week away Dave, looking forward to a resolution! :)
stokerfatlad
hi all just a quick update
i checked all wires coming from car to tailgate and couldnt  a broken
i took it to a friends garage and he could not find the fault he rang and autoelectriction
he know they changed the boot catch and electric motor and match it up with software and now it works at a cost of £200 all in
How did they get the boot open, given that it was locked shut?
Full Colour Version: Boot Trouble
