Full Version: The Advantages Of Synthetic Oils Over Mineral Oils
oilman
[b]The Advantages of Synthetic Oils over Mineral oils[/b]
Extended oil drain periods
Better wear protection and therefore extended engine life
Most synthetics give better MPG
They flow better when cold and are more thermally stable when hot
Surface-active meaning a thin layer of oil on the surfaces at all times (in ester based oils)
[b]How Synthetic oils Achieve these Benefits[/b]
[b]Stable Basestocks[/b]
Synthetic oils are designed from pure, uniform synthetic basestocks, they contain no contaminants or
unstable molecules which are prone to thermal and oxidative break down.
Because of their uniform molecular structure, synthetic lubricants operate with less internal and
external friction than petroleum oils which have a non-uniform molecular structure.
The result is better heat control, and less heat means less stress to the lubricant.
[b]Higher Percentage of Basestock[/b]
Synthetic oils contain a higher percentage of lubricant basestock than petroleum oils do.
This is because multi-viscosity oils need a great deal of pour point depressant and viscosity improvers
to operate as a multigrade.
The basestocks actually do most of the lubricating. More basestocks mean a longer oil life.
[b]Additives Used Up More Slowly[/b]
Petroleum basestocks are much more prone to oxidation than synthetic oils. Oxidation inhibitors are
needed in greater quantities in petroleum oils as they are used up more quickly.
Synthetic oils do oxidize, but at a much slower rate therefore oxidation inhibiting additives are used up
more slowly.
Synthetic oils provide for better ring seal than petroleum oils do. This minimizes blow-by and reduces
contamination by combustion by-products. As a result, corrosion inhibiting additives have less work to
do and will last much longer in a synthetic oil.
[b]Excellent Heat Tolerance[/b]
Synthetics are simply more tolerant to extreme heat than petroleum oils are. When heat builds up
within an engine, petroleum oils quickly begin to burn off. They are more volatile. The lighter
molecules within petroleum oils turn to gas and what's left are the large molecules that are harder to
pump.
Synthetics have far more resistance as they are more thermally stable to begin with and can take
higher temperatures for longer periods without losing viscosity.
[b]Heat Reduction[/b]
One of the major factors affecting engine life is component wear and/or failure, which is often the
result of high temperature operation. The uniformly smooth molecular structure of synthetic oils gives
them a much lower coefficient friction (they slip more easily over one another causing less friction)
than petroleum oils.
Less friction means less heat and heat is a major contributor to engine component wear and failure,
synthetic oils significantly reduce these two detrimental effects.
Since each molecule in a synthetic oil is of uniform size, each is equally likely to touch a component
surface at any given time, thus moving a certain amount of heat into the oil stream and away from the
component. This makes synthetic oils far superior heat transfer agents than conventional petroleum
oils.
[b]Greater Film Strength[/b]
Petroleum motor oils have very low film strength in comparison to synthetics. The film strength of a
lubricant refers to it's ability to maintain a film of lubricant between two objects when extreme pressure
and heat are applied.
Synthetic oils will typically have a film strength of 5 to 10 times higher than petroleum oils of
comparable viscosity.
Even though heavier weight oils typically have higher film strength than lighter weight oils, an sae 30
or 40 synthetic will typically have a higher film strength than an sae 50 or sae 60 petroleum oil.
A lighter grade synthetic can still maintain proper lubricity and reduce the chance of metal to metal
contact. This means that you can use oils that provide far better fuel efficiency and cold weather
protection without sacrificing engine protection under high temperature, high load conditions.
Obviously, this is a big plus, because you can greatly reduce both cold temperature start-up wear and
high temperature/high load engine wear using a low viscosity oil.
[b]Engine Deposit Reduction[/b]
Petroleum oils tend to leave sludge, varnish and deposits behind after thermal and oxidative break
down. They're better than they used to be, but it still occurs.
Deposit build-up leads to a significant reduction in engine performance and engine life as well as
increasing the chance of costly repairs.
Synthetic oils have far superior thermal and oxidative stability and they leave engines virtually varnish,
deposit and sludge-free.
[b]Better Cold Temperature Fluidity[/b]
Synthetic oils do not contain the paraffins or other waxes which dramatically thicken petroleum oils
during cold weather. As a result, they tend to flow much better during cold temperature starts and
begin lubricating an engine almost immediately. This leads to significant engine wear reduction, and,
therefore, longer engine life.
[b]Improved Fuel Economy[/b]
Because of their uniform molecular structure, synthetic oils are tremendous friction reducers. Less
friction leads to increased fuel economy and improved engine performance.
This means that more energy released from the combustion process can be transferred directly to the
wheels due to the lower friction. Acceleration is more responsive and more powerful, using less fuel in
the process.
In a petroleum oil, lighter molecules tend to boil off easily, leaving behind much heavier molecules
which are difficult to pump. The engine loses more energy pumping these heavy molecules than if it
were pumping lighter ones.
Since synthetic oils have more uniform molecules, fewer of these molecules tend to boil off and when
they do, the molecules which are left are of the same size and pumpability is not affected.
Synthetics are better and in many ways, they are basically better by design as they are created by
chemists in laboratories for a specific purpose, rather than being modified from something that came
out of the ground to be as good as they can for a purpose.
Tim
DanGersFord
Very interesting topic :) will keep all this in mind when changing my oil in future although im surebit was fully synthetic oil I used the last time
FOCA
Tim, - If traditional mineral/ petrolium based oil is made from refined crude oil "dug out of the ground" (/fossil fuel)
What is synthetec oil made from?
oilman
Here you go
http://www.opieoils.co.uk/pdfs/tech-articles/Basestock-categories-and-Descriptions.pdf
Tim
FOCA
Here you go
Tim
Thanks for that - so you get group 1, 2  and 3 that are made from crude oil, and group 3 is often marketed as synthetec or semi synthetic - so
1 - How can you tell if the oil you buy is a "true" synthetic, manufactured from "manufactured/ chemically engineered" base stocks (group 4 & 5) and not from crude oil ? / is there a way of telling on the markings on the retail packaging of the oil?
2 - if the "true" synthetic oil in group 4 & 5 is made from "chemically engineersd basestocks" what are these basestocks made from?  (yes i know they are  synthetics made in labs by chemists desinged for the application ....etc) - im just wondering where they get their raw materials from ?
oilman
Hi
Technically, they don't have to say whether the oil is mineral based or a proper synthetic, but companies are giving more information out in slightly disguised ways now. Motul put Technosynthese on the group 3 oils. Mobil 1 oils are proper synthetics, Mobil Super are group 3. Castrol Edge are group 4, Magnatec are group 3. Amsoil are all group 4. Redline are group 4 and 5 blends.
The properly synthetic basestocks are made from reacting other chemicals, such as organic acids and alkalis.
Tim
