Full Version: SRS ECU
Ford Owners Club - Ford Forums > United Kingdom - General Ford Discussions by Model > Ford C-Max Club
Paul14
Hi
Can anyone help I can't find my SRS ECU on my 2008 1.8 tdci C-MAX, I need to send it away to have a fault erased,I was told it was under the plastic cover around the gear lever which was quite tricky to get out but there was no ECU their, dont what to rip into any thing else until I know where it is Help!
SierraYankee99
[quote name='Paul14' post='17314' date='Mar 31 2009, 10:19 AM']Hi
Can anyone help I can't find my SRS ECU on my 2008 1.8 tdci C-MAX, I need to send it away to have a fault erased,I was told it was under the plastic cover around the gear lever which was quite tricky to get out but there was no ECU their, dont what to rip into any thing else until I know where it is Help![/quote]
Not sure on yours but mines under the centre console between the handbrake and gear lever. To help its also called the Airbag Control Module. I wouldnt go taking it out though on a 1 year old car. Take it to the dealership it should be covered under warranty
why send it away to have it cleared just get ford to reset it under warrenty.
Paul14
[quote name='SierraYankee99' post='17327' date='Mar 31 2009, 11:11 AM']Not sure on yours but mines under the centre console between the handbrake and gear lever. To help its also called the Airbag Control Module. I wouldnt go taking it out though on a 1 year old car. Take it to the dealership it should be covered under warranty[/quote]
Thanks i will look there, can't take to ford don't what to let them know its been in a shunt just yet.
sr-performance
you dont need to take ecu out mate to clear fault, try your local garage.. your too far away or i would have done it for you.. free.
steve
www.sr-performance.co.uk
Paul14
[quote name='sr-performance' post='17477' date='Mar 31 2009, 10:57 PM']you dont need to take ecu out mate to clear fault, try your local garage.. your too far away or i would have done it for you.. free.
steve
www.sr-performance.co.uk[/quote]
Thanks for the offer but i has tried my mates garage and won't clear fault code which is B1231 longitudual acceleration threshold exceeded. The only way is a new ecu or send it away.
fordtech
As far as i know you can't clear that code (it's also stored in the gem if i remember correctly) , anyway we can normally tell if it's been in a bump , unless you managed to get it repaired by one of the very few repairers that are excellent.
Full Colour Version: SRS ECU
