Full Version: Ford Focus 2005 Central Locking Problem
ccking2006
Hi all. I have just purchased a Ford Focus 2005 1.8 TDCI. I can use the key to get into the car but the central locking is not working. I have a key fob for the car and when i press the fob i can hear the the central locking box in the foot well clicking.
I have checked all fuses
I have oiled and WD'd the lock on the door and the central locking unit
also the boot release catch is not working from inside of the car
jacksargent93
Have you tried re-programming the key?
ccking2006
is that were u turn it 8 times. yes
wen i do this i get to the 5 turn and there is a beeping coming from the dash and wen ive done the 8 turns nothing happens
Dan62
pugsley82
re programed worked for me when had simular
jacksargent93
When you get that beeping to complete the re-programme you have to press a button on the key but I'm not sure which one - I know I aint much help haha
ccking2006
all fuses ok
i can not fined the box to reprogram it pic my help me if any one has some
no i did not not press a buttan on the key fob after i terned it 8 times i new there was some thiing i did not do lol
Insert the ignition key and turn from position II (Ignition) to position 0 (All off) and back four times within three seconds.
Remove the ignition key.
The locking control system is now in "learn mode" for the next 20 seconds and you should hear a chime to indicate this.
During the 20 seconds press one of the transmitter buttons.
The remotes signal and code number is learned by the locking module and is indicated by another chime.
Wait until learn mode times out (20 seconds) or switch the ignition back to ON
ccking2006
ok i will give this a go today and i will get back to u thanks
ccking2006
ok tryed that and i get the bleeping but still nothing is going on only a slite clicking noise coming from the fut well wen i press the key fob buttons
Sounds like your central locking relay has died then.
ccking2006
is this in the fuse box or in the foot well can u tell me whitch one it is and a pic if u have one so i can go to scrp yardand get one thanks
ccking2006
ok i found the fuse at the back of the fuse box it hade blone
i wood like to say thanks for all your help :)
