Full Version: 2012 Focus Alarm
Llew
The alarm on my 2012 focus estate keeps going off during this hot weather. I assume that its the heat & over sensitivity that sets it off. What really worries me is what if it goes off when I am not around. Will it go off indefinitely or is there a cut out after a period of time.  Currently it seems to go off for about 30 seconds then stops, and restarts soon again. I am assuming that there is a cut off when it won't start all over again,- anybody know?
Llew
Normally alarms go off anywhere between around 30 seconds to 5 minutes, and the alarm noise stops, the indicators may continue to flash for up to 15 minutes, however the alarm shouldn't persist for longer than this.
I would advise taking the car back to Ford, as the sensitivity should be reduced or any faulty part should be replaced under warranty.
Preee
To pin it down to the sensors , on swithcing ignition off , select to deactivate the sensors , then if it does not go off you know its a sensor fault.
Mine tends to trip in winter months if i have had the temp high and get out of the car quickly and then it triggers. , If i get out of the car and let a decent ammount of new air into the car it does not go off.
Foci_st3
Never had an issue with mine
Full Colour Version: 2012 Focus Alarm
