T955daytona
April 5, 2009, 3:09 am
Hi, I have a 2005 KA 1.3 which is missing the rear sensor rings off the inside of the drum. I called ford and ordered two replacement rings but the ones that arrived appear to be too big. They are smooth and appear to be magnetic. I have checked on an older abs equipped fiesta with the same size drums and that has a bumpy (corrugated) sensor fitted which is the same size as I appear to need. Have ford given me the wrong part or is something amiss. At present the abs light is on due to no signal from the rear sensors. Will the old style ring fit my car or does the abs work differently on the later cars. There are 2 different electrical sensors listed for pre and post 2004. Any help gratefully received.
April 5, 2009, 8:16 am
the rings were altered in 2004 if your rings are too big it looks like ford has given you the wrong set. your car might have been built pre 2004 but not registered untill 2005. your vin number should tell fords when it was manufactored.
