Full Version: ! Guide ! Installing A Sub Box To Mk7
Ford Owners Club - Ford Forums > Ford Models > Ford Fiesta Club > Ford Fiesta Guides
Pages: 1, 2
TitaniumSteve
I am writing this guide in addition to my first guide to help others if they want to install a sub box into the Mk7 using a RCA convertor to create pre amps out.
Firstly I will add that this is not a simple job and I would not advise this to be done by a novice. How ever I hope my guide will make it easier for anyone trying to do the same. Also I will add for those that are screamish :lol: this does invole taking apart a 3 week old car, but absolutly no damage was done to my new little car.
So here we go.
Take out the front head unit, refer to my [url="http://www.fordownersclub.com/forums/index.php?showtopic=4636&st=0"]FIRST[/url] guide to do this. Once you have the head unit out you will have to disconnect two multi blocks from the rear of the unit, disconnect both and remove head unit to a safe place. The smaller multi block is just data cables. The connection you are interested in is the larger multiblock. When you look the block you will see 5 pairs of wires top n bottom plus a single cable on its own. The single cable on its own is the ignition live (only goes live when ignition is on). At the other end of the block you will see two fatter cables, the cable with black on it is the ground, and the other is the permannet live. The other eight cables which are a variety of colours are the speaker cables. The top row is the positive and bottom is negative.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0034.jpg[/img]
Now take your RCA convertor on it you will have two positive speaker cables and two negative speaker cables. To avoid cutting cables you can push a bare end cable into the back of the multi blocks so push two positive into the top row and two positive into the bottom row. It is not important which speaker connection you use just as long as you use the same for both neg and pos. On your RCA convertor you will also have a positive and negative cable, again push the bare end cable from your RCA convertor into the appropriate neg and pos connection on the multi block. Now with your ampilifier kit you will be supplied with a long blue remote live cable, this cable is pushed into the back of the ignition live cable (the single cable on the multi block), this will mean your amp will on go on when your ignition is on.
Next you will have to feed your RCA cables, (supplied with your amp), your blue remote cable and your power cable to the rear of the car. First tie off your RCA cable and remote cable to something at the head unit so you dont pull them through.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0029.jpg[/img]
It is fairly easy to feed your RCA cables and your remote cable down from the head unit to the floor. You can then tuck them in behind the carpet, and lead them to the small side panel on the passenger side.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0030.jpg[/img]
Now you can take your main min 8 gauge power cable and connect it to the battery.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0033.jpg[/img]
Then this cable can be fed down through a hole next to the washer bottle which will bring it out by the inner arch wheel trim. Thread it round the arch, and by the door hinge you will see some foam sound insulation, this can be moved to the side so the cable can be fed through the hinge to the interior.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0028.jpg[/img]
Now lift up the rubber waterproof trim and feed 3 cables along it, the power cable the RCA cable and the remote cable, and they will now come out by the rear seats.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0031.jpg[/img]
It is now possible to pass all 3 cables along the side of the back seat so that they come out in the boot.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0032.jpg[/img]
Now just when you thought you were done you now have to create an Earth cable, this should be as short as possible and taken from the rear. I used one of the 13mm bolts that hold seat belt mounting in. Simple take out bolt connect your earth cable and put bolt back in.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0036.jpg[/img]
Now the fun bit connect all those cable up to your amp. I am using a active sub, meaning the amp is bulit into the sub box. To test it temporarily reconnect the front head unit and dash and power it up to see if it all works, (remember to turn on your ignition).
[img]http://i50.photobucket.com/albums/f345/bart100/Image0035.jpg[/img]
It should all now come on. With me it all worked first time, I was very pround of myself.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0038.jpg[/img]
You can now put the car carefully back together. I did this whole job without a single scratch and no damage to the car at all, the entire system could be taken out without any sign that had been there.
I hope this guide has been of some use. Any questions then please ask.
Steve
JAR897
Wicked guide. I'm considering doing it.. what SUB did you use and how much did it cost?
I want to see how to initial speakers sound first. Also, how much room did it take in your boot - Can you upload a photo of your boot now please?
Thanks.
Jonny87
Very nice Steve. Just out of interest, is that red power cable visible around the passenger door frame?
JAR897
OK so I'm now looking very hard into different subs and alike. I'm looking in perticular at this one: [url="http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_504817_langId_-1_categoryId_165748"]
Vibe CBR12 Active Evo Subwoofer[/url]
Would this fit the bill?
Also, What kind of difference does it make to the overall audio? Is it a significant improvement over the already existing sound (i.e. is it a 200 improvement?) lol.
My friends have installed a sub before (granted in a corsa) so i will have some help - I would go for halfords 'WeFit' but I'm nervous they will scratch things and do a bodge job anyway.
Still in 2 minds - Will mull it over with father tomorrow - He always has words of wisdom.
TitaniumSteve
[quote name='Jonny87' post='18388' date='Apr 5 2009, 10:53 PM']Very nice Steve. Just out of interest, is that red power cable visible around the passenger door frame?[/quote]
At the moment it is visible about 3 inch of it, however I am going to be fitting some black trunking to go over it. I would have done it today just forgot.
[quote name='JAR897' post='18390' date='Apr 5 2009, 11:06 PM']OK so I'm now looking very hard into different subs and alike. I'm looking in perticular at this one: [url="http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_504817_langId_-1_categoryId_165748"]
Still in 2 minds - Will mull it over with father tomorrow - He always has words of wisdom.[/quote]
It is funny you should mention that speaker set up, as it is the 10 inch version I have. Picture below shows the boot, I would say that the 12 inch would be to big better going for 10 inch. I have not driven car since I fitted the unit, so i have only listen to it whilst I was testing it out and yes I am very happy with the sound, not sure if I would spend 200 on doing it thro. I had this unit spare in my garage has I took it out of my other car, my other car I have just built a fully customised 600 boot install for it. It was not worth selling this unit so into the fezzer it went, this unit cost 150.
And no don't go anywhere near Halfords for doing this job, unless you want a spotty 18 year old poking screwdrivers around the paintwork of your new car.
[img]http://i50.photobucket.com/albums/f345/bart100/Image0039.jpg[/img]
JAR897
Yea probably true. Not much boot space - Although I don't really have anything to carry. Lol.
I will have to wait and see what I think of the normal speakers.
Thanks for all the info tho Steve!
Jonny87
Cheers Steve, is there no way of bringing the power cable straight into the car from the front?
TitaniumSteve
[quote name='Jonny87' post='18394' date='Apr 5 2009, 11:34 PM']Cheers Steve, is there no way of bringing the power cable straight into the car from the front?[/quote]
I looked into taking it thro the bulkhead but without taking out the glove box this would be hard. All the cables passing thro the bulkhead are above the height of the glove box. The cable I have installed is barely visible and will be even better with trunking on it. There may be another way to bring the cable inside as I did not spend ages looking but I am happy with the way I done it, if you find another easier way let me know.
Jonny87
Thanks for the reply Steve, please post a pic when you have trunking, ta
Jon
Nipz
Amazing guide :) but i still dont get why people want to take up all their boot space with a huge sub :P
KeithC
[quote name='Nipz' post='18418' date='Apr 6 2009, 10:21 AM']Amazing guide :) but i still dont get why people want to take up all their boot space with a huge sub :P[/quote]
Coz it's the biz wiv all that booming, innit. ;)
Nipz
[quote name='KeithC' post='18427' date='Apr 6 2009, 11:41 AM']Coz it's the biz wiv all that booming, innit. ;)[/quote]
lol give me a woop woop!
TitaniumSteve
Just done my first day working in my car with my sub on in between lesson and my sound system sounds so much better than the original one. That is why plp do it because it makes what u are listening to sound pleasurable and not tiney. Anyway its not like I need the boot to carry a fridge around in it and there is plenty of space for the shopping.
JAR897
I'm looking at the exact same sub you have Steve for 139 from [url="http://caraudiosecurity.com/shop/product/products_id/2923.html"]HERE[/url]! What do you think?
I would install it myself - but am a perfectionist and would not want ANY wires to be showing ANYWHERE without using ANY trunking etc.
Also, could you point the sub sideways to free up more room in your car. How is the sub secured to the boot so it doesn't roll around?
squaddiefox
couple of things, i know i haven't posted much so i hope you don't mind, with the power cable running next to the audio cable you are likely to get a slight whistling sound as you accelerate from the subwoofer. the best way to avoid it is to run the cables either on opposite sides or run one up the middle of the car and the other down the side.
is that power cable fused? if not i would get a fuse in their sharpish, no point paying out good money for a car and audio equipment and frying it when you get a voltage peak and burn out the power cable to the amplifier. as you said, it runs passed sound proofing which is quite combustible.
one last thing, why point the sub to the rear of the car? just makes the boot vibrate and makes a decent guitar riff sound crap if turned up.
JAR897
I realy want to install a sub into the back. The space isn't an issue so I don't mind that. I am however apprihensive to installing the sub - I would get halfords to do it for me but it's rediculously priced. I'm going to order the same sub as Steve (159 I think?).
Where did you get your sub from Steve?
Do you think halfords would install a sub I didn't buy directly from them?
Would halfords make a mess of my new beauty?
Does the sub effect the insurance?
It's the wiring I'm worried about, such as where the power cable goes etc..
I would also mount the sub sideways to save space... And possibly put it on the 40% seat split to allow the 60% seat to be folded down and utalised if needed.
I think the installation will be a bit tricky though.
Any tips or things I will need specifically? Thanks!!
squaddiefox
if you need a hand mate, pop round to mine (after the weekend as im going off-roading) i've done a few installs. i'll let you do the bits, as you will know what you are doing then. i'll help you out with the positioning of wires and routing and sort all the connections and any difficult bits for you. im only in brum, kings norton. im not a rip off merchant like halfrauds either!
TitaniumSteve
[quote name='squaddiefox' post='18570' date='Apr 7 2009, 03:15 AM']couple of things, i know i haven't posted much so i hope you don't mind, with the power cable running next to the audio cable you are likely to get a slight whistling sound as you accelerate from the subwoofer. the best way to avoid it is to run the cables either on opposite sides or run one up the middle of the car and the other down the side.
one last thing, why point the sub to the rear of the car? just makes the boot vibrate and makes a decent guitar riff sound crap if turned up.[/quote]
You are absolutly right about the power cable it is meant to be on a different side to the control cables I meant to put this in my write up. I was aware of this when I was doin the job however I wanted to keep the job fairly simple and has my car has dual controls fitted to it already I did not have to worry about upsetting the carpet on both sides etc. Plus it is only a 'maybe' that you will get interference has it depends on all sought of this, like how well car is earthed, how well it is screened from other cables plus how good the quality of the cable is. This is proven with my set up as I have been driving with sub installed for couple of days now and I have absolutly no interference at all.
Point 2. Of course the power cable is fused this this I assumed was basic. My guide was not meant to be a full degree course it is a guide. There is loads and loads of detail I could have gone into has I have been installing sound system in cars for 20 years, but I did not have time to write a thesis.
point 3. It makes no diffrence at all as to which way you point the subs as bass is non directional, what will make the car vibrate is if it is turned up to loud and if the car does not have sound insulation. I will repeat this is a very basic install it is not meant to be a full boot install it cost 150 hardly a pro install, my other car I have recently spent hundreds and hundreds of pounds and several weekends setting up with a full boot install. My fiesta is my works car and I only installed the sub to 'enhance' the sound not to take to a ICE show.
My guide was only to help plp out as it is a new desighn car and I assumed nobody would know how to take them apart confidently, I was merely trying to help out. :D
squaddiefox
ok, no worries, i was just pointing out a few things. as some may not be aware.
try turn it round and check the difference, some cars it does make a difference as the bass reverberates on the bootlid. most of which are hollow so make a nasty sound. some cars or ears will hardly notice it.
Robs-Zetec-S
Hi Steve,
I Thought Your Step By Step Was Top Job, Just Finishing Wiring It Up To Me 1.6 TDCi Zetec-S,
Just Two Quick Questions,
Does It Matter If I Go Through Either The Front Or Rear Speakers For An RCA Point?,
Ive Taken the Out Put From The Rear Speakers?,
And Which Settings Have you Got The Headunit On?, I Just Seem To Be Getting Alot Of Bass From The Front Only get the Sub Coming In Small Amounts lol,
Sounds Gud Atm But Want Abit More From The Rear, Could You Help?,
Thanks Again Steve,
Regards,
Rob
Luke Pompey
Thanks! Used your guides to get it all installed. Can't get a decent Earth tho :(
Petey1978
Can anyone tell me wires are for the front speakers and which are the rear. I want to make sure my sub is on the front speakers as sometimes I fade sound to the front only as it gets too loud for passengers in the rear.
beatty36
[quote name='JAR897' post='18536' date='Apr 6 2009, 10:36 PM']I'm looking at the exact same sub you have Steve for 139 from [url="http://caraudiosecurity.com/shop/product/products_id/2923.html"]HERE[/url]! What do you think?
Also, could you point the sub sideways to free up more room in your car. How is the sub secured to the boot so it doesn't roll around?[/quote]
You can now get an adaptor for active subs, which means that you can simply plug the sub in and it will work, leaving all the wires where they are. This will mean that you can have the extra boot space when you need it and its very easily installed. I htink they only cost about 10 pounds if even. SHould be on the halfords website.
plunder
Hello there...
Do you have a link to this or any more information?
I looked on the Halfords site but could not find it.
thank you,
Mark.
Ronnie Roberts
is it possible to run the power cable through the wing and then in through the door gromet which runs the electric window cables from door - car? thats the way we usually puy them in... bit fiddly but least it hides the cables...
i didnt want to loose boot space so im looking at the pioneer TS-WX11A as it fits under the passangers seat... not massive bass but its the best of both worlds... comes with the stereo to rca convertor and the amp is built in... only downside! the price!!!
also considered the TS-WX77A but its stupid money!!
Focus_ST-3
I am also looking at the Pioneer TS-WX 11A. Do you think it would fit under the spare wheel?
I cant justify 100 extra for the TS-WX77A
Ronnie Roberts
[quote name='fiesta_zetec-x' post='42411' date='Sep 9 2009, 03:39 PM']I am also looking at the Pioneer TS-WX 11A. Do you think it would fit under the spare wheel?
I cant justify 100 extra for the TS-WX77A[/quote]
not sure but i would be a little concered with air flow and cooling if it was in the spare wheel compartment...
i thought the 77 was 140 more? i know the rrp is stupid on the 77! Im planning to put the 11 under drivers seat and just leave it there!
spitfire123
what direction would you point the sub in then matey?
without it looking poo...
cheers
plunder
[quote name='Petey1978' post='28746' date='Jun 14 2009, 12:25 PM']Can anyone tell me wires are for the front speakers and which are the rear. I want to make sure my sub is on the front speakers as sometimes I fade sound to the front only as it gets too loud for passengers in the rear.[/quote]
Hi there,
Is titaniumsteve still about?
I too would love to to know what the colour codes are for the front (4 speakers) and the rear (2 speakers) on the back of the headunit?
Anyway of getting a wiring diagram for this from anywhere? There is nothing in the manual that i can see.
Mark.
InstructorPiggy
Just a suggestion, all install I do, I run the power cable under the car, cable tie at regular inetrvals normally to the other cables running underside, then come up in the boot either through a drainage plug (hole in it, then sylcone) or drive a hole, seal and grommet.
Just need to jack up the one side!!
Think I may consider amping just the speakers and replace standard speakers...
Or the spare wheel well is a handy size...could build a sub box to fit in there or you can gt compact sub boxes...means you wouldn't lose room :)
Good guide....still don't get how you got the two speaker jacks to amp to go into the multipoint connector??? :huh:
Luigi 200
Right, my 12" Vibe CBR Active Sub is in my boot, I've run my audio cables driver side and my power cables passenger side! (All Good)
I'm running the sub through the rear speakers, if your going to do this i recommend doing it properly, i see where Steve is coming from and it can be taken out without anyone knowing but i can see the wires popping out all the time! and the effort to get the dash out is not worth the hassle
i have scalpeled off the plastic coating on 2mm of the wire b4 the multiblock, you dont even have to take the cd player out. just disconnect the multiblock below it. i then soldered on my converter cables (2 postive, 2 negative and a ground cable) then i put insulation/electrical tape round the joins. this way there is a solid connection, it will not come out and it will sound better.
this is how a professional fitter would do the job! you could take all off it off and all you would see is a bit of bare cable on the speaker cable, this would be covered by insulation tape and it would be back to normal.
Its been asked a couple of times now which cables are the rear speakers, the top level are positive and the bottom are negative, the rear speakers are not next to eachother on the block, they are the WHITE/BROWN AND BLUE/BROWN the other rear speaker is GREEN/WHITE AND BROWN/YELLOW
Also on my 59 Fiesta, might be different from steves but i wouldnt of thought so, there is a couple of extra cables in the multiblock next to the speaker cables, they have a 3/4 V current passing through them, im not entirely sure what these are for but leave them be! dont connect speakers too them, i think it could get ugly! use a multimeter to find these cables and steer clear :) other than that a pretty simple install, just take your time.
This job is definately worth doing its a really good upgrade!
Any questions please ask :)
Mikey
Jonny87
Any pics of where you have connected stuff up? power, earth, and suchlike?
Luigi 200
ill take pics of it all tonight and post on, steves original place of grounding for the sub is perfect.. works a treat.
i found a cheeky hole while the bonnet was open for the power cable to go through, it then goes into the car via the main door gromet, so you cant see any cables unless you look seriously hard haha its then fed down into the door well along with the remote (battery) live cable
was my first fit (had done some speaker changes before though) and went really well! :)
beatty36
Thats idiotic!!! You have a live cable running along the passenger door on the outside, then along the side of the rear passenger!
Luigi 200
[quote name='beatty36' post='58238' date='Jan 5 2010, 05:49 PM']Thats idiotic!!! You have a live cable running along the passenger door on the outside, then along the side of the rear passenger![/quote]
beatty36 your clearly an idiot and have no idea what your going on about....
the live cable is fully insulated and fused and both ends...
live cables run all the way through the car...
beatty36
[quote name='plunder' post='37065' date='Aug 13 2009, 03:21 AM']Hello there...
thank you,
Mark.[/quote]
Hey mate, sorry it took so long. But yeah i dont know where they are on the halfords site but if you go onto ebay its called a vibe fast plug. Really neat wee gadget. Hope this helps.
beatty36
[quote name='Luigi 200' post='61224' date='Jan 22 2010, 06:19 PM']beatty36 your clearly an idiot and have no idea what your going on about....
live cables run all the way through the car...[/quote]
Clearly, lol thinking of somthing else.
LeeZetecS
[size="2"]
[font="Franklin Gothic Medium"]Did you manage to get some photo's of what you were describing about part of this install.
I want to finish a list of stuff i need before i start this upgrade.[/font][/size]
curtis-mk4
hi , ive got an amp and bass, im wandering does it connect to the orginal ford head unit (mk4 fietsa) cheers
Mk7_Rbj
Please have a look at my posts [url="http://www.fordownersclub.com/forums/index.php?showtopic=13258&st=15&gopid=100972&#entry100972"]here in my progress thread[/url] and let me know if you can help..
RBJ
mpkayeuk
[quote name='Luigi 200' timestamp='1261479193' post='56083']i have scalpeled off the plastic coating on 2mm of the wire b4 the multiblock, you dont even have to take the cd player out. just disconnect the multiblock below it. i then soldered on my converter cables (2 postive, 2 negative and a ground cable) then i put insulation/electrical tape round the joins. this way there is a solid connection, it will not come out and it will sound better.[/quote]
I'm looking at fitting an active sub, the low profile Pioneer one, into my Zetec. However, why would you make a permanent change to the Ford loom (albeit hidden) when you could get an SOT (also known as a Parrot lead) from Autoleads like this:
[url="http://bit.ly/eAcIl0"]http://bit.ly/eAcIl0[/url]
Then you have converted the Ford loom to an ISO loom inline and you can make a custom ISO lead to take off just the outputs you need to run to the rear of the car (i.e. the rear speakers or RCAs and ignition power). All this without effecting the operation of the OEM head unit. That's what I'm going to do I think. Any reason why this is a bad idea? Is there enough room in the dash for this approach?
kemik
Mikey
Hey Mikey,
i've just fitted a sub to my fiesta but im getting a popping sound from one of the phono cables. Its not power or interference from the air as when you swap the connections round the interference switches to the other lead. Im stumped and dont know here to go from there. Can anyone help please? Thanks.
Kemik.
cmw1992
im using one of these [url="http://www.amazon.co.uk/Connects2-Adapter-CTVFOX003-Ford-Fiesta/dp/B004S6KY2G"]My link[/url] but i have connected everything up and no sound is coming from the sub, can anyone help?
D4nz0
[quote name='cmw1992' timestamp='1318015573' post='147477']
wow! That looks really cool, much better than using other methods..... but my only worry s the lack of a trustworthy brand.
But back to your problem. You will need to give a bit more detail.... first off, is your amp turning on? Fuses all connected and ok?
If you're amp's power light is coming on, then it can only really be between the head units RCA's, or the wiring to sub.... maybe headunit settings? checked the bias goes to rear as well as front? If you don't have the option of front and rear bias (which some Fez's don't) then that could be your issue if the unit is only outputting front signal.... I think Ford can update the cars software to fix this so no big deal I don't think.
Danny
cmw1992
yer they are so simple just plug in and play but not sure if they actually work :P
to your questions the light in the amp is on and fuses are good. i have tryed changing the earth and making a better connection to the sub from the amp but still nothing. do you think the problem will be with the rca's?
Also im a bit confused, do you have to conect the amp to the rear speakers?
cheers
D4nz0
if the amp is on then you definitely have no problems with your earth, live or remote cables.
I've just done some reading up on this, after googling the serial number of it.... and it turns out those RCA's are for input. E.g. get a 3.5mm jack to RCA cable and plug in your iPod.
That's the reason you're getting no sound, coz they're not outputting anything ;)
You're gonna need to get a couple of these http://www.ebay.co.uk/itm/FLI-Line-Level-Car-Rear-Speaker-Wire-RCA-Converter-/140508487826?pt=UK_In_Car_Technology&hash=item20b6f56092#ht_3040wt_982
and plug them into the rear speakers wires. I just linked first set I found with a reputable name, but do a search for RCA Line Converter and see what you find.
Danny
cmw1992
top man cheers for that think ill prob pop to halfords cos i know they sell them.
thanks for the help hopefully ill have it up and running tomorrow :)
Nice Guide Mate [img]http://www.fordownersclub.com/forums/public/style_emoticons/default/cool.gif[/img]
will help lots of people
cmw1992
finally got my sub going, when you have it all conected you apreciate how good this guide is!
FordCom18
[color=#000000][font=arial, sans-serif][size=4]Hello I[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]am also working[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]with a subwoofer for[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]my[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]ford[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]fiesta[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]MK7[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]of 2011[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]I[/size][/font][font=arial, sans-serif][size=4]'ve[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]done[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]all the steps[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]that[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]can be found here[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]o[/size][/font][font=arial, sans-serif][size=4]n[/size][/font][font=arial, sans-serif][size=4]show[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]your topic[/size][/font][font=arial, sans-serif][size=4], I have[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]only[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]1 problem[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]and that[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]is the remote[/size][/font][font=arial, sans-serif][size=4], you[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]can help[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]me[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]sometimes[/size][/font][font=arial, sans-serif][size=4]?[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]by[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]easy to explain[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]exactly where he[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]should[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]sit or[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]with photographs[/size][/font][font=arial, sans-serif][size=4] [/size][/font][font=arial, sans-serif][size=4]to
Thank you[/size][/font][/color]
