Full Version: Water Visible In Drivers Footwell Dribbling Down Rhs
tomtommad
i have looked at other posts re incorrect pollen filter fitting etc, i have replaced mine and it seals fine, i have a steady stream in water running in on the drivers footwell it is quite visible when it has rained and its running from behind kick panel then soaking the carpet front and back, the washer hoses have been checked rear wash also checked all washer hose connectors are fine , any suggestions on where this mystery dribble could be coming from
tearing hair out
muchly appreciate any advice
steve 2.0 TDCI Mondeo Ghia X 2007 MK3
Hi Steve,
Is there any water marks behind the scuttle panel under the bonnet? suggesting the water may have ran into the air intakes and down from there?
Check if the filter or housing are wet.
The seal may look ok but might be pinched somewhere.
also you didnt saw where in the drivers footwell you can see the water?
tomtommad
removed pollen filter housing and cleaned out leaves etc, then used mastik to re seat housing, cleaned the windscreen lip,
(long piece of grooved plastic the windscreen sits on), cleaned everything.  waiting for some rain to see if it dribbles in, if it still does i will post a pic of where it dribbles inco footwell
many thanks people, fingers crossed
steve
stooge75
i dont think it'll be ur filter takin water in,but hope so for you though. thinking it might be coming in thru beside pedals maybe. had a mate had water trickling down inside o door pillar etc & ended up at his feet.
tomtommad
Finally sorted the wet floor in drivers footwell. Before I got the car the windscreen had been replaced the fit was not perfect , along the drivers side seal of glass to car. Was letting in water. Solution was to dry out remove weather strip and use black mastic to resell windscreen. Now all ok. Hope this helps other Mondeo owners. Thanks for all advise. Steve
Glad to see you got it resolved!
