isc111
April 10, 2009, 12:41 pm
I have a 54 plate 1.8 petrol Mondeo. The engine warning light has recently illuminated apparently permanently. I have used the tripmeter 'trick ' (found elsewhere on the internet) to check for a dtc fault code - normally in the form XXXXX (letter followed by four numbers). However the code given is: 'E 01'. This does not appear to be listed in any Ford dtc library. Can any body help?
Thank you
SierraYankee99
April 11, 2009, 2:06 am
[quote name='isc111' post='19286' date='Apr 10 2009, 06:51 PM']I have a 54 plate 1.8 petrol Mondeo. The engine warning light has recently illuminated apparently permanently. I have used the tripmeter 'trick ' (found elsewhere on the internet) to check for a dtc fault code - normally in the form XXXXX (letter followed by four numbers). However the code given is: 'E 01'. This does not appear to be listed in any Ford dtc library. Can any body help?
Thank you[/quote]
I'm pretty sure that just means theres one error logged. To determine the error you'd need a code reader.
