Full Version: Escort gear linkage HELP
demonteddy
Hi, I have an Escort 1300L it was made with a 5spd box but the person i bought it from changed it to 4spd.
The problemi have is that when i fitted a 5spd box i am only get 1,2,3and 4th gear, cant get reverse or fifth.
Are the linkages different for 4spd and 5spd?
If so my engine is an OHV will the linkage from a CVH gearbox fit the OHV gearbox the local car dismanterles
dont have any 5spd Mk4 Escorts in only 4spd, I got the gearbox from a fiesta the breakers said they are the same gearbox.
the gearbox did go straight in.
This is the first time i have ever worked on a transverse engine maybe i havnt lined something up
Desperatly need help i need my car back on the road.
Thankyou in advance for your advice
demonteddy
homeless
you need a five speed gear selector.....
demonteddy
[quote name='homeless' post='19473' date='Apr 11 2009, 08:48 PM']you need a five speed gear selector.....[/quote]
I thought that what i wanted to know was will a cvh gear selector fit i cant get a ohv 5spd selector there are loads of
CVH mk 4 cars in breakers, just hard to get hold of OHV 5spd in breakers
homeless
[quote name='demonteddy' post='19544' date='Apr 12 2009, 12:38 AM']I thought that what i wanted to know was will a cvh gear selector fit i cant get a ohv 5spd selector there are loads of
A cvh one will be fine...best to set them up in reverse and go from there.
You may see on your selector rod coming out of the gearbox that there is a rust tide line...try and use that as a guide when lining them up, and have someone else in the drivers seat checking it for you as you go to save to getting up and down...it will take a little while to get it perfect, but you will get there.
Good luck :)[/quote]
demonteddy
Thankyou homeless
I will get the CVH 5spd selector and hopefully get back on the road, I should have relised that the selectors would be different
i didnt want to change the gearbox back to a 4spd after all the hell i went through fitting the 5spd box, this is the first time i have ever fitted
a gearbox to a transerve engine And the last.
I do have another question my Escort just has the normal clocks i was thinking of fitting clocks with a rev counter instead will it just plug straight in or
do i need to rewire
Thanks again
demonteddy
homeless
You can just need to take one wire to the coil for a RPM source...i did this years ago on an Mk3 GL and i added XR3 clocks..ghia ones would do too, when removing them from another car ask the scappy if you can cut the plugs off 2 this will u.
Good luck mate.. :) and no problem ;)
demonteddy
Hi Thanks for advice will have a go at putting a rev counter on.
Sorted the gear linkage out by using a 5spd linkage just need to fine tune it,
I can drive it but will have to adjust linkage till i get it spot on, another day tho
i need a break from working on it LOL
thanks
demonteddy
Full Colour Version: Escort gear linkage HELP
