Full Version: Bad Intermittent Idle
garytaxi
Hi
I hope I am on correct forum as new to this one, I just wondered if anyone has had the problem
that my car is having, I have a 2012 mondeo zetec  2.0 litre diesel.
it is used as a taxi and has 26000 miles on clock, I have noticed on occasion that car
idles poorly with rev counter jumping from the usual 750rpm idle up to around 850
and down to 500rpm, when this is going on car seems to be backfiring slightly
this can last for several minutes and then car return's to usual idle
when this first happened I put it down to dpf regeneration, ? but it seems to be happening
more often now at first it was once a week or so, then twice but yesterday it happened again
And the day before, so am getting concerned , it will clear up if you drive in a lower gear for a mile or so
But is becoming a pain apart from that I like car. am taking it to dealers soon as due oil change shortly
btmaldon
I am no expert on diesels, but I would think a fuel filter change may help.
stooge75
your EGR could be sticking maybe,but you'd have to check.or fuel filter
,mmm. unusual for taxi driver to give up a car at 26k unless he knows something you dont,maybe. i would(as btmaldon says),check filter,EGR valve,then if that doesnt work,get someone to plug it in toFord IDS,& see what comes up. cant see it being anything severe though unless said taxi drivers been using bio-diesel etc.(& a lot do,up here).
could be something silly like a sensor,but really,you're only going to find that out if you plug it in.
other day I saw a BMW with very similar symptoms to you,& it WAS his DPF. Mechanic stuck it in a bucket of cleaner for a day,then revved the hell outta car,& problem solved.i was amazed at the stuff that came outta the exhaust when revving it to clean it
mick85
I would say u need a PCM upgrade u would need go main dealer common problem
garytaxi
Thanks for advice it had crossed my mind about filter , but think I will wait to see what dealer says as still under warranty
Thanks I seem to have confused with the way I wrote post , I am a Taxi driver, and have only had car 9000 miles
But I will have filter renewed and get them to check egr and if required get them to stick it on their equipment
Cheers help much appreciated I have decided to contact dealer
So hopefully it will be something as simple as you have suggested
Full Colour Version: Bad Intermittent Idle
