HI there
I have a ford focus ST170 fitted with Xenon headlamps as standard. I noticed a few oncomimg motorist was flashing me at night i.e. dip your headlights you P***********R. I then noticed that the dip beam does appear to be high against the background, I know that these are self levelling in operation and consist of a couple of level sensors on each axle and a control module to make them work.
The car just had a MOT in the last fortnight and the lights were ok then.
Has anybody had this type of problem with ford focus Xenon headlamps???? :unsure:
Is this a module fault or a level sensor fault, I assumimg that both headlamps are working ok since both are affected??????? :unsure:
your thoughts are much appreciated
regards
:o :o :o
